Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] 3 way join, how to do?
[Teneo] 3 way join, how to do? [message #113984] Thu, 06 March 2008 07:26 Go to next message
I am adapting a security service to use Teneo as the persistance layer.
The original system had a Role table, a Group table, a Permission table
and a User table. There was a table to join the Group, User and Role
information together. e.g. USER_GROUP_ROLE primary key (USER_ID,
GROUP_ID, ROLE_ID).
I am using the teneo.jpa annotations but from the examples cannot work
out how I woudl represent this, or whether I need to create an element
that actually models this.
A couple of small things I noticed too.
eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//String"
is used int he examples, this no longer exist is and I cannot find it. I
wanted to see the full set of XMLType values.
A more general thing, I worked on a project (dentaku at codehaus.org)
where we use stereotypes and tagged values in the UML to specify column
types and lengths etc. Then generated the Hibernate file from that. With
ECore there does not seem to be a way to do this so you end up with a
messy process, UML model then hand edit the ECore created from it to add
teneo.jap annotations. Any way of improving this? A second difficulty is
that with large XSDs produced as part of a standard it would be nice
if you could have the teneo.jpa annotations in a separate file so that
when a new version of that standard is released it is easier to manage
the changes, the only way to automate this I can see now is to write a
mega XSLT script to merge two files to add the teneo annotations to the
standard XSD.
Thx.
David
Re: [Teneo] 3 way join, how to do? [message #113997 is a reply to message #113984] Thu, 06 March 2008 08:03 Go to previous message
Hi David,
See my comments inline.
gr. Martin
david wrote:
> GROUP_ID, ROLE_ID).
MT>> As far as I can see you would need to model a separate element to accomplish. Let me know if
you come to another conclusion.
MT>> I am not 100% sure if you mean this but the xml types are all in the XMLType package:
org.eclipse.emf.ecore.xml.type.XMLTypePackage and its impl. class.
MT>> See my answer below regarding setting annotations outside of the ecore.
Regarding specifying column types/lengths on another level than specific eattributes/ereferences,
Teneo supports annotations (for column types/lengths) on EDataTypes. Then each EAttribute which uses
this EDataType will automatically get these annotations applied. I would also like something similar
for EReference but there is no EDataType for EReferences in ecore. Maybe Ed can comment in more
detail on this.
Regarding stereotypes and emf there are a number of posts related to this topic on the emf newsgroup
(search for stereotype in the header). I am not sure if newer versions of EMF have some sort of
automatic stereotype to eannotation mapping.
If so it could be an idea to allow tagging modelelements with a stereotype/eannotation and then
allow specification of jpa annotations on this tag level. If this sounds interesting then please
open a bugzilla so that it gets on the to-do list (and we can discuss it there).
> that with large XSDs produced as part of a standard it would be nice if
> you could have the teneo.jpa annotations in a separate file so that when
> a new version of that standard is released it is easier to manage the
> changes, the only way to automate this I can see now is to write a mega
> standard XSD.
MT>> Teneo also allows you to set annotations in a separate xml (actually my prefered way of working):
http://www.elver.org/hibernate/ejb3_format.html#xml
So then you don't need to edit the ecore.
Is this what you mean?
> Thx.
> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] 3 way join, how to do? [message #615617 is a reply to message #113984] Thu, 06 March 2008 08:03 Go to previous message
Hi David,
gr. Martin
david wrote:
> GROUP_ID, ROLE_ID).
detail on this.
> standard XSD.
> Thx.
> David
The Netherlands
Previous Topic:[Teneo] 3 way join, how to do?
Next Topic:teneo: same name problem using jpox
Current Time: Mon Jul 21 22:06:56 EDT 2025
Powered by FUDForum. Page generated in 0.05693 seconds
