Home » Archived » BIRT » Birt.war methode=post
Birt.war methode=post [message #113932] Tue, 24 January 2006 05:43 Go to next message
I have update on BIRT 2.0.0 warfile on Tomcat 5.0
after this update
<form method="POST" target="Birt" action="../birt-viewer/run"
accept-charset="utf-8">
<input type="hidden" name="__report"
value="report/IMSuite_Statistik_Page_02.rptdesign">
<input type="hidden" name="OG_NAME" value="Gebaeudestruktur">
<input type="hidden" name="__format" value="pdf">
<td align="right">
<button class=kkTButton type="submit">
<img border="0" src="static/img/viewpdf.gif" alt="IM-Suite Statistik"
align="absMiddle" width="16" height="16">
</button>
</td>
</form>
doesn't work.
When I change to
<form method="GET" target="Birt" action="../birt-viewer/run"
<td align="right">
</button>
</td>
</form>
then he works.
Is this a bug?
Kurt
Re: Birt.war methode=post [message #114601 is a reply to message #113932] Tue, 24 January 2006 13:48 Go to previous message
You can log a bug for it so we can trace this issue.
So far, this is not a bug. New web viewer introduce a soap layer whose
entry point is also viewer servlet. Post method is more or less used to
identify the incoming request. The incoming request could be ordinaral url
access (get), or ajax post.
Probably we should reserve the viewerservlet for extenal integration and
create new servlet entry point for soap request onyl.
Previous Topic:Unknown fonts
Next Topic:Birt 2.0RC1 problem with PDF
Current Time: Mon Jul 07 21:35:41 EDT 2025
Powered by FUDForum. Page generated in 0.04274 seconds
