Home » Archived » BIRT » Birtviewer failures
Birtviewer failures [message #113919] Tue, 24 January 2006 04:38 Go to next message
Originally posted by: jan.tanis.coas.com
I just installed BIRT 2.0 and I discovered some problems I had before
with the BIRT frameset viewer. In FireFox it is showing nothing but a
blank page... and the JavaScript errors offcourse. The same is for IE. I
hope this will be fixed soon as I'm dying to see the new release working
proper. Keep up the good work.
Regards, Jan.
Re: Birtviewer failures [message #114625 is a reply to message #113919] Tue, 24 January 2006 13:50 Go to previous messageGo to next message
What's the firefox version you are using? 1.5 or 1.0. We currently onlu
support 1.0.
Also check whethet you get prototype.js. I can not think of any other
issue if you see the error on IE.
Re: Birtviewer failures [message #115090 is a reply to message #114625] Wed, 25 January 2006 01:41 Go to previous messageGo to next message
> support 1.0.
Yes, I do use 1.5.
Yes, that one was missing. Maybe I should upgrade less to avoid such
things;)
Regards, Jan.
Re: Birtviewer failures [message #115258 is a reply to message #115090] Wed, 25 January 2006 04:00 Go to previous message
I'm having the same problems with Firefox: Using the frameset it displays
a blank page and the JS-Console shows a whole lot of errors. I have tested
with Firefox 1.5 and 1.0.7, same result. Everything is fine though when
not using the frameset.
Why was the fact that Firefox 1.5 is not supported, yet, not published
more clearly in the release notes?!!! I don't remember seeing a hint or a
warning anywhere!
Furthermore, the last web viewer release I used for testing was 2.0 M3 and
that worked fine with Firefox 1.5. I didn't necessarily expect this to
change in the final release.
When do you expect to support Firefox? 80% of the people in my company
prefer Firefox and now they can't take advantage of the (btw well done)
AJAX features of the 2.0 web viewer.
Thanks ... Jan
Previous Topic:PDF column width - auto adjust
Next Topic:creating callbacks on charting components
Current Time: Tue Jul 22 15:36:51 EDT 2025
Powered by FUDForum. Page generated in 0.04279 seconds
