Home » Modeling » TMF (Xtext) » Copying a whole folder
Copying a whole folder [message #870529] Tue, 08 May 2012 10:43 Go to next message
Hello, I need to generated a folder, in the src-gen where its generated the code from dsl files. I explain:
I have this folder in the computer:
../res
and inside it more folders and files.
And in the dsl project I have something like that:
../myProject/
src-gen/example.php
example.mydsl
I want to generate the folder res inside src-gen. Is it posible???
../myProject/
src-gen/
example.php
res/
example.mydsl
And in the other answer I didnt understand nothing:
What do I have to do????
You have to configure an OutputConfiguration for folder /res by providing an customized IOutputConfiguration, bind it in the runtime module of your DSL project and generate at least one file to this output configuration. The IFileSystemAccess has a method which takes the output configuration name as a second argument.
~Karsten
I dont know what it means.
Thanks a lot for the help.
Re: Copying a whole folder [message #870575 is a reply to message #870529] Tue, 08 May 2012 15:26 Go to previous message
what Karsten said: there is NO out of the box solution for that. one possible hook is a custom IFileSystemAccess.
another possibility is a custom org.eclipse.xtext.builder.IXtextBuilderParticipant.
You would subclass org.eclipse.xtext.builder.BuilderParticipant and override handleChangedContents.
Here you have access to the IFileSystemAccess as well.
Since you do not want to generate to the src-gen folder but to the res folder you would need a
own OutputConfiguration for that folder. => Bind a own OutputConfigurationProvider
Never the less you have think about a solution for getting the stuff and copying it yourself
=> Maybe you should do the copy the resources task not with the builder but rather with a classic action/handler or wizard.
Previous Topic:Referencing generated code from other DSL files.
Next Topic:xtext generator unittest with xtend
Current Time: Thu Jul 17 06:07:46 EDT 2025
Powered by FUDForum. Page generated in 0.06887 seconds
