Home » Archived » BIRT » Data access issue
Data access issue [message #113889] Tue, 24 January 2006 03:45
Originally posted by: jan.tanis.coas.com
Hi all,
I've noticed that the setProperty() method of an Implementation of
IQuery is called after the prepare() function. Isn't it usefull to call
the setProperty() method before the prepare() function. In that case I
can use some properties in my prepare() function. Otherwise I have to
fit all my properties in a single String.
What do you think about this? Or does someone know whom to discuss this
with? Regards Jan.
Previous Topic:The output format pdf is not supported!! What's the problem?
Next Topic:UnsupportedClassVersionError-- Integrating with WSAD5.1
Current Time: Tue Jul 22 03:21:43 EDT 2025
Powered by FUDForum. Page generated in 0.06668 seconds
