Home » Modeling » TMF (Xtext) » One plugin muliple project
One plugin muliple project [message #870101] Sun, 06 May 2012 09:14 Go to next message
Hi all,
Is it possible to define a project with 2 different dsl. Where every grammar has its own file extension.
Re: One plugin muliple project [message #870102 is a reply to message #870101] Sun, 06 May 2012 09:23 Go to previous messageGo to next message
Yes. Simply add multible language blocks to the workflow. Never the
less: is there a specific reason you want to do so?
Re: One plugin muliple project [message #870109 is a reply to message #870102] Sun, 06 May 2012 11:25 Go to previous messageGo to next message
I need a plugin which support two different files extension with two grammar, but the second grammar is a subset of the first.
Is it also possible to define multiple file extensions for a grammar?
Re: One plugin muliple project [message #870111 is a reply to message #870109] Sun, 06 May 2012 11:46 Go to previous messageGo to next message
Yes it is. Simply specifying a file extension list (comma separated)
in the workflow should do the trick
Re: One plugin muliple project [message #870222 is a reply to message #870111] Mon, 07 May 2012 06:32 Go to previous messageGo to next message
I developed a little project:
MyDsl.xtext
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "xtext.org/example/mydsl/MyDsl"
ImportDeclaration: {ImportDeclaration}
			'import' ('static')? Name ';'
MyNewDsl.xtext
grammar org.xtext.example.mydsl.MyNewDsl with org.xtext.example.mydsl.MyDsl
generate myNewDsl "xtext.org/example/mydsl/MyNewDsl"
import "xtext.org/example/mydsl/MyDsl" as DSL
Package: {Package}
			'ciao 'impor=Name '!'
GenerateMyDsl.mwe2
module org.xtext.example.mydsl.MyDsl
import org.eclipse.emf.mwe.utils.*
import org.eclipse.xtext.generator.*
import org.eclipse.xtext.ui.generator.*
var grammarURI = "classpath:/org/xtext/example/mydsl/MyDsl.xtext"
var grammarURI2 = "classpath:/org/xtext/example/mydsl/MyNewDsl.xtext"
var file.extensions = "mydsl"
var file.extensions2 = "nxn,xdl"
var projectName = "z.xtext.example.mydsl"
var runtimeProject = "../${projectName}"
Workflow {
    bean = StandaloneSetup {
		platformUri = "${runtimeProject}/.."
	component = DirectoryCleaner {
		directory = "${runtimeProject}/src-gen"
		directory = "${runtimeProject}.ui/src-gen"
	component = Generator {
		pathRtProject = runtimeProject
		pathUiProject = "${runtimeProject}.ui"
		projectNameRt = projectName
		projectNameUi = "${projectName}.ui"
		language = {
			uri = grammarURI
			fileExtensions = file.extensions
			// Java API to access grammar elements (required by several other fragments)
			fragment = grammarAccess.GrammarAccessFragment {}
			// generates Java API for the generated EPackages
//			fragment = ecore.EcoreGeneratorFragment {
			// referencedGenModels = "uri to genmodel, uri to next genmodel"
				referencedGenModels="classpath:/model/JavaVMTypes.genmodel"
			// the serialization component
			fragment = parseTreeConstructor.ParseTreeConstructorFragment {}
			// a custom ResourceFactory for use with EMF
			fragment = resourceFactory.ResourceFactoryFragment {
			// The antlr parser generator fragment.
			fragment = parser.antlr.XtextAntlrGeneratorFragment {
			  options = {
					backtrack = true
					classSplitting = true
		    fragment = parser.antlr.XtextAntlrUiGeneratorFragment {
			  options = {
					backtrack = true
			// java-based API for validation
			fragment = validation.JavaValidatorFragment {
				composedCheck = "org.eclipse.xtext.validation.ImportUriValidator"
				//composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
				// registerForImportedPackages = true
			// scoping and exporting API
			fragment = scoping.ImportNamespacesScopingFragment {}
			fragment = exporting.QualifiedNamesFragment {}
			fragment = builder.BuilderIntegrationFragment {}
			// formatter API
			fragment = formatting.FormatterFragment {}
			// labeling API
			fragment = labeling.LabelProviderFragment {}
			// outline API
			fragment = outline.TransformerFragment {}
			fragment = outline.OutlineNodeAdapterFactoryFragment {}
			fragment = outline.QuickOutlineFragment {}
			fragment = types.TypesGeneratorFragment {}
			// quickfix API
			fragment = quickfix.QuickfixProviderFragment {}
			// content assist API
			fragment = contentAssist.JavaBasedContentAssistFragment {}
			// generates a more lightweight Antlr parser and lexer tailored for content assist
			fragment = parser.antlr.XtextAntlrUiGeneratorFragment {}
		language = {
			uri = grammarURI2
			fileExtensions = file.extensions2
			  options = {
					backtrack = true
			  options = {
					backtrack = true
			// formatter API
			// labeling API
			// outline API
			// quickfix API
I haven't error lauching the MWE WORKFLOW and even launching the plugin, but it don't recognize the "MyNewDsl" grammar and its extension, any suggestion?
Re: One plugin muliple project [message #870343 is a reply to message #870222] Mon, 07 May 2012 13:28 Go to previous messageGo to next message
did you create a new project using the wizard or did you adapt an existing one.
if you adapted an existing dont forget to merge plugin.xmk_gen -> plugin.xml
~Christian
Re: One plugin muliple project [message #870374 is a reply to message #870343] Mon, 07 May 2012 16:46 Go to previous messageGo to next message
thanks Cristian, I merged the plugin.xml file but now when I create an nxn file I get this error:
!SESSION 2012-05-07 22:43:05.136 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_30
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
Framework arguments:  -product org.eclipse.platform.ide
Command-line arguments:  -product org.eclipse.platform.ide -data C:\Users\Giuseppe\Desktop\eclipse_1_prove\workspace/../runtime-XTEXT -dev file:C:/Users/Giuseppe/Desktop/eclipse_1_prove/workspace/.metadata/.plugins/org.eclipse.pde.core/XTEXT/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.emf.ecore 2 0 2012-05-07 22:43:42.860
!MESSAGE Both 'z.xtext.example.mydsl.ui' and 'z.xtext.example.mydsl.ui' register an extension parser for 'mydsl'
0    [main] WARN  org.eclipse.xtext.internal.ExtensionResourceServiceProviderRegistryReader  - Both 'z.xtext.example.mydsl.ui' and 'z.xtext.example.mydsl.ui' register a content parser for 'mydsl'
!ENTRY org.apache.log4j 2 0 2012-05-07 22:43:42.877
!MESSAGE org.eclipse.xtext.internal.ExtensionResourceServiceProviderRegistryReader  - Both 'z.xtext.example.mydsl.ui' and 'z.xtext.example.mydsl.ui' register a content parser for 'mydsl'
64041 [main] ERROR org.eclipse.xtext.ui.editor.CompoundXtextEditorCallback  - different instances of editor were given.
java.lang.IllegalStateException: different instances of editor were given.
	at org.eclipse.xtext.ui.editor.AbstractDirtyStateAwareEditorCallback.beforeDispose(AbstractDirtyStateAwareEditorCallback.java:37)
	at org.eclipse.xtext.ui.editor.CompoundXtextEditorCallback.beforeDispose(CompoundXtextEditorCallback.java:70)
	at org.eclipse.xtext.ui.editor.XtextEditor.dispose(XtextEditor.java:382)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:705)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
	at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:289)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2863)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2768)
	at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2760)
	at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2711)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2707)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2691)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2682)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
	at org.eclipse.ui.wizards.newresource.BasicNewFileResourceWizard.performFinish(BasicNewFileResourceWizard.java:111)
	at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:811)
	at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:430)
	at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
	at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
	at org.eclipse.jface.window.Window.open(Window.java:801)
	at org.eclipse.ui.internal.actions.NewWizardShortcutAction.run(NewWizardShortcutAction.java:135)
	at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
	at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
	at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
!ENTRY org.apache.log4j 4 0 2012-05-07 22:44:46.918
!MESSAGE org.eclipse.xtext.ui.editor.CompoundXtextEditorCallback  - different instances of editor were given.
!ENTRY org.eclipse.ui 4 0 2012-05-07 22:44:46.918
!MESSAGE Unable to create editor ID org.xtext.example.mydsl.MyNewDsl: Editor could not be initialized.
!STACK 0
java.lang.IllegalStateException: The resource factory registered for platform:/resource/MultipleD/src/temp/tmp2.nxn does not yield an XtextResource. Make sure the file name extension is correct (case matters).
	at org.eclipse.xtext.ui.editor.model.ResourceForIEditorInputFactory.createResource(ResourceForIEditorInputFactory.java:77)
	at org.eclipse.xtext.ui.editor.model.ResourceForIEditorInputFactory.createResourceFor(ResourceForIEditorInputFactory.java:69)
	at org.eclipse.xtext.ui.editor.model.ResourceForIEditorInputFactory.createResource(ResourceForIEditorInputFactory.java:61)
	at org.eclipse.xtext.ui.editor.model.JavaClassPathResourceForIEditorInputFactory.createResource(JavaClassPathResourceForIEditorInputFactory.java:37)
	at org.eclipse.xtext.ui.editor.model.ResourceForIEditorInputFactory.createResource(ResourceForIEditorInputFactory.java:49)
	at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.setDocumentContent(XtextDocumentProvider.java:102)
	at org.eclipse.ui.editors.text.StorageDocumentProvider.createDocument(StorageDocumentProvider.java:229)
	at org.eclipse.ui.editors.text.FileDocumentProvider.createElementInfo(FileDocumentProvider.java:735)
	at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.createElementInfo(XtextDocumentProvider.java:131)
	at org.eclipse.ui.texteditor.AbstractDocumentProvider.connect(AbstractDocumentProvider.java:400)
	at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(AbstractTextEditor.java:4056)
	at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(StatusTextEditor.java:217)
	at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetInput(AbstractDecoratedTextEditor.java:1444)
	at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor.java:169)
	at org.eclipse.xtext.ui.editor.XtextEditor.doSetInput(XtextEditor.java:149)
	at org.eclipse.ui.texteditor.AbstractTextEditor$19.run(AbstractTextEditor.java:3043)
	at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
	at org.eclipse.jface.window.ApplicationWindow$1.run(ApplicationWindow.java:759)
	at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWindow.java:756)
	at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:2606)
	at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(AbstractTextEditor.java:3061)
	at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTextEditor.java:3088)
	at org.eclipse.xtext.ui.editor.XtextEditor.init(XtextEditor.java:169)
	at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:798)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:647)
!ENTRY org.eclipse.ui 2 2 2012-05-07 22:44:46.934
!MESSAGE Ignored attempt to add saveable that was already registered
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: unknown saveable: org.eclipse.ui.internal.DefaultSaveable@1adf5e1 from part: org.eclipse.ui.internal.ErrorEditorPart@1adf5e1
	at org.eclipse.ui.internal.SaveablesList.logWarning(SaveablesList.java:187)
	at org.eclipse.ui.internal.SaveablesList.addModel(SaveablesList.java:117)
	at org.eclipse.ui.internal.SaveablesList.addModels(SaveablesList.java:289)
	at org.eclipse.ui.internal.SaveablesList.postOpen(SaveablesList.java:684)
	at org.eclipse.ui.internal.PartList.partOpened(PartList.java:234)
	at org.eclipse.ui.internal.PartList.access$0(PartList.java:210)
	at org.eclipse.ui.internal.PartList$1.propertyChanged(PartList.java:40)
	at org.eclipse.ui.internal.WorkbenchPartReference.fireInternalPropertyChange(WorkbenchPartReference.java:375)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:610)
Re: One plugin muliple project [message #870377 is a reply to message #870374] Mon, 07 May 2012 16:56 Go to previous messageGo to next message
Hmmm,
i think the best is:
- create a new project with the wizard
- adapt the workflow
- run the workflow
btw i use Xtext 2.x you seem to use 1.x
~Christian
Re: One plugin muliple project [message #871082 is a reply to message #870377] Thu, 10 May 2012 14:05 Go to previous message
Yes I use Xtext 1.x, it don't work even starting a new project.
But on Xtext 2.x everything works fine. I think I must migrate on Xtext 2.x.
Thanks Cristian
Previous Topic:[Solved] Custom content Assist
Next Topic:2.3.0 M6 JVM generation and Enums
Current Time: Mon Jul 14 23:39:36 EDT 2025
Powered by FUDForum. Page generated in 0.22179 seconds
