[Teneo] What is the best way to check if EMF resource has been updated in the datastore? [message #113832] |
Tue, 04 March 2008 04:42  |
Originally posted by: vnikolov.us.ibm.com
I was wondering what is the best way (performance wise) to check if EMF
resource has been updated in the DB i.e. to find out if there are any
differences between the EMF resource in the memory and the data in the DB.
I'm using Teneo with JPOX.
For example: My application loads a resource and outputs all
elements.(like "Load the resource" section here:
http://www.elver.org/jpox/tutorial1/tutorial1_5.html)
Then some other part of the code adds another element in the db.
In order to get the updates I should reload the resource.
But how I can find out if there is difference between the EMF resource
in the memory and the resource representation in the DB without calling
resource.load()?
Vladimir
Re: [Teneo] What is the best way to check if EMF resource has been updated in the datastore? [message #113854 is a reply to message #113832] |
Tue, 04 March 2008 06:20  |
Hi Vladimir,
Assuming that you only want to check for updates of currently loaded objects then you can use the
getNonResolvingAllContents method on the jpoxresource to get an iterator which does not load lazy
loaded lists. Then iterate over it and check if the in-memory version is different from the version
in the db. The in-memory version number can be obtained by casting to PersistenceCapabale and
calling jdoVersion, the db version is present in the e_version column (you need to do a query to get
it).
gr. Martin
Vladimir Nikolov wrote:
> Hello,
> resource.load()?
> Vladimir
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] What is the best way to check if EMF resource has been updated in the datastore? [message #615606 is a reply to message #113832] |
Hi Vladimir,
it).
gr. Martin
> Hello,
> resource.load()?
> Vladimir
The Netherlands
FUDForum. Page generated in 0.14473 seconds
