Home » Modeling » GMF (Graphical Modeling Framework) » how to make objects moveable within container
how to make objects moveable within container [message #113807] Thu, 22 March 2007 12:43 Go to next message
Hi All,
I've just started using a container in a node in my editor. What I'd like
to have is something similar to one of the containers in the Taipan
example. The one where you can add large and empty boxes to the ship node.
I've got my container working but when I add elements into the container
they stay fixed to the left hand side. I'd like to be able to freely move
these around within the container. I've tried copying all the settings
from the Tiapn example but the nodes still appear fixed to the left hand
side.
Also, I was looking at the viewlet for the mindmap container tutorial
http://www.eclipse.org/gmf/tutorial/viewlets/tutorial2.html (didn't see
anything set here either to indicate how to let elements within a
container to move freely) and noticed that when the collapsible tab was
clicked, which I have in my container, that the node shrunk back to its
original/optimal size. When I shrink my container the node stays the same
size. How would I be able to change it so node returns to original size on
shrinking the compartment.
Thanks very much for your help,
Gaff
Re: how to make objects moveable within container [message #114013 is a reply to message #113807] Fri, 23 March 2007 08:35 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
Maybe you use list compartment instead of shape compartment? There is
boolean property in compartment element to select it's type.
Gaff wrote:
> Hi All,
> like to have is something similar to one of the containers in the Taipan
> node. I've got my container working but when I add elements into the
> container they stay fixed to the left hand side. I'd like to be able to
> freely move these around within the container. I've tried copying all
> the settings from the Tiapn example but the nodes still appear fixed to
> the left hand side.
> same size. How would I be able to change it so node returns to original
> size on shrinking the compartment.
> Gaff
Re: how to make objects moveable within container [message #114035 is a reply to message #114013] Fri, 23 March 2007 10:34 Go to previous messageGo to next message
Hi Dimitry,
That sounds like waht I need to change. I can't find it my application or
in the Taipan example. In the Taipan example I can see two compartment
elements (I presume you mean the ones in the gmfgraph model?) for large
and small cargo. In their properties there are Collapsible, Figure, Name
and Needs Title. Can't see the boolean property you're talking about.
Could you point out in where in the Taipan example it is?
Gaff
Re: how to make objects moveable within container [message #114054 is a reply to message #114035] Fri, 23 March 2007 10:48 Go to previous messageGo to next message
See gmfgen model; GenCompartment.listLayout
Gaff wrote:
> Hi Dimitry,
> or in the Taipan example. In the Taipan example I can see two
> compartment elements (I presume you mean the ones in the gmfgraph
> model?) for large and small cargo. In their properties there are
> Collapsible, Figure, Name and Needs Title. Can't see the boolean
> property you're talking about. Could you point out in where in the
> Gaff
Re: how to make objects moveable within container [message #114063 is a reply to message #114054] Fri, 23 March 2007 10:52 Go to previous message
Sorry, just found it, thanks for your help.
Previous Topic:Help ... GMF with RCP
Next Topic:Extra layer over GMF diagram
Current Time: Sun Jul 27 12:43:19 EDT 2025
Powered by FUDForum. Page generated in 0.04007 seconds
