CheckedTreeSelectionDialog [message #113801] |
Thu, 21 August 2003 09:50  |
I'm trying to provide dialog using:
org.eclipse.ui.dialogs.CheckedTreeSelectionDialog
whereby the user can select elements from a tree. Th selection aspect
works fine, however I'm having problems setting the initial state of the
tree when the user returns to the dialog. I have a list of previously
checked elements, taken using:
CheckboxTreeViewer cbtv = this.getTreeViewer();
Object[] allFilters = cbtv.getCheckedElements();
However when I try and reconfigure the tree with this selection, it
doesn't seem to work:
((CheckboxTreeViewer)this.getTreeViewer()).setCheckedElement s(allFilters);
No errors, no nothing.
Any help with this frustrating problem, much appreciated.
James
Re: CheckedTreeSelectionDialog [message #113898 is a reply to message #113801] |
Thu, 21 August 2003 10:43  |
Just to add, the method below does work for the root item of the tree.
But not for any of the sub branches.
James Willans wrote:
> James
FUDForum. Page generated in 0.03319 seconds
