Home » Eclipse Projects » Eclipse Platform » CheckedTreeSelectionDialog
CheckedTreeSelectionDialog [message #113801] Thu, 21 August 2003 09:50 Go to next message
I'm trying to provide dialog using:
org.eclipse.ui.dialogs.CheckedTreeSelectionDialog
whereby the user can select elements from a tree. Th selection aspect
works fine, however I'm having problems setting the initial state of the
tree when the user returns to the dialog. I have a list of previously
checked elements, taken using:
CheckboxTreeViewer cbtv = this.getTreeViewer();
Object[] allFilters = cbtv.getCheckedElements();
However when I try and reconfigure the tree with this selection, it
doesn't seem to work:
((CheckboxTreeViewer)this.getTreeViewer()).setCheckedElement s(allFilters);
No errors, no nothing.
Any help with this frustrating problem, much appreciated.
James
Re: CheckedTreeSelectionDialog [message #113898 is a reply to message #113801] Thu, 21 August 2003 10:43 Go to previous message
Just to add, the method below does work for the root item of the tree.
But not for any of the sub branches.
James Willans wrote:
> James
Previous Topic:Console window(s)
Next Topic:Project property page no longer exists...
Current Time: Sat Jul 19 11:08:37 EDT 2025
Powered by FUDForum. Page generated in 0.03840 seconds
