Home » Eclipse Projects » Commercial » Crystal Reports for Eclipse available for FREE!
Crystal Reports for Eclipse available for FREE! [message #10381] Sat, 12 August 2006 15:29 Go to next message
------=_NextPart_000_0050_01C6BE0A.F4F07EB0
Content-Type: text/plain;
charset="iso-8859-1"
Crystal Reports for Eclipse is a free set of plugins provided by the =
makers of Crystal Reports, the world's #1 Report Designer. Crystal =
Reports for Eclipse will provide Eclipse developers with an embedded =
report designer as well as a number of development tools to assist the =
developer with building applications.
=20
Below is a list of features available with the Crystal Reports for =
Eclipse product.
=20
Report Design
=20
=20
a.. New Report Designer built on the Eclipse Framework - built from =
the ground up using Business Objects' award winning Java Reporting =
Component (JRC) engine=20
b.. Drag & Drop Report Design - drag objects from the Palette or Field =
Explorer on to the report design pane=20
c.. Free form placement - don't be bound to nesting tables in your =
report. Drag and drop your report objects exactly where you want them to =
show up on your report=20
d.. Auto-generate SQL statements - SQL query is auto-generated based =
on the database fields added to the report=20
e.. Design off of POJOs - drag and drop your Java classes on to your =
report to use the class definition in your report design=20
f.. Cross-Tab reports - design cross-tab reports to easily visualize =
grouped data=20
g.. Java User Function Library (UFL) support - access external Java =
logic from within your Crystal Reports formulas=20
h.. Multiple Data Source support - use the visual database pane to =
easily create links between multiple data sources=20
i.. Integrated Code Assist - Use the built-in Eclipse Code Assist =
feature when building Crystal Reports formulas. Crystal syntax will =
display errors and display code assist within the Formulas pane
=20
=20
Development Tools
=20
=20
a.. Crystal Reports Web Project- this feature will enable developers =
to create a web project which already includes all of the required =
runtime configurations. Additionally, developers can optionally choose =
to add a sample database and reports to the project to get up and =
running in no time=20
b.. JSP Page Wizard-Drag 'n' drop a report onto a JSP page, or create =
a new JSP page via the context menu of a report. This wizard will =
provide developers with a dialog page allowing them to choose a number =
of different stub code which will be custom generated based on the =
selected report. Does your report require parameters, do you want to =
change the database at runtime, or export directly to PDF...the wizard =
will generate all of the required code to complete the requested =
actions, all custom to the specific report. You can literally get away =
with never having to write a line of reporting code again=20
c.. Java Reporting Component facet-easily add the Crystal Reports =
runtime environment to any new or existing web applications. Now you =
will never have to worry about ensuring that all your JAR files have =
been added=20
d.. Deployment Assistance - Never have to worry about ensuring the =
proper JDBC drivers are available at runtime. When a report is added to =
a project, the tooling will ensure that the required runtime libraries =
are present (including database libraries) when the application is =
built.=20
e.. Update your projects with the latest runtime-have you just =
downloaded a hot fix, but are not too sure if you have already added it =
to an existing project. Use the Crystal Reports File Versions feature =
accessed via the Properties Menu of a project to quickly and easily see =
which file versions are currently in your project and compare this with =
the file versions installed in the tooling. If they are out of synch =
click the Update button to easily update your application to the latest =
version.=20
f.. Global Property Settings-do you find that you are always turning =
off the logo on the viewer, or enabling the refresh button? Well, now =
Developers can set their global settings for the Crystal Report viewers =
within their workspace preferences. Each time a viewer is added to a JSP =
page these preferences will be honored and the appropriate code =
modifications will be added=20
g.. Java User Function Library wizard-this feature enables developers =
to expose Java logic to their Crystal Reports formulas. Does your =
organization have a large amount of code already invested into =
calculating a discount ratio? Don't fret, wrap this logic up in a User =
Function Library using this easy wizard and your Crystal Reports files =
will be able to access this same logic=20
h.. Built-in pointers to the Business Objects' Update Site-never have =
to worry about whether you have the latest version or not. Use the =
existing Eclipse Update Manager mechanism to check for updates and =
install them automatically. This feature also has built-in rollback =
capabilities in case you opt to go back to a previous version=20
i.. Integrated Help-Access a complete and robust report designer guide =
as well as developer walkthroughs, API docs and Best Practices via the =
built-in Eclipse Help System
=20
=20
On top of all this developers will find a large amount of resources =
(including free forums, video tutorials and whitepaper tutorials) =
available at our Developer Community Site =
(http://diamond.businessobjects.com/eclipse/)
=20
=20
All of these features are completely FREE for developers to download and =
deploy in production. However, if you need more out of the runtime =
engine, Business Objects also has a Professional version of Crystal =
Reports for Eclipse. This version will be available on the Business =
Objects' e-store and offer the following upgrades for the Developer:
=20
a.. More Power - a runtime engine that provides up to 5X more report =
processing power=20
b.. Technical Support- each copy of Crystal Reports for Eclipse =
Professional includes 2 support incidents. Allowing the Developer to =
contact Business Objects' world class support organization directly=20
c.. License for Multiple Server Deployments - if you need to =
distribute your application on multiple servers (e.g. web farms, web =
gardens, etc.) then you will require the Professional license
=20
Crystal Reports for Eclipse Professional can be purchased from our =
online store for $495US per server. For more information about our =
pricing and licensing options check out the following article.
Content-Type: text/html;
<HTML xmlns:o =3D "urn:schemas-microsoft-com:office:office" xmlns:st1 =
=3D=20
"urn:schemas-microsoft-com:office:smarttags"><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1555" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV>
<P class=3DMsoNormal style=3D"MARGIN: 0in 0in 0pt"><FONT face=3D"Times =
New Roman"=20
size=3D3><SPAN style=3D"FONT-SIZE: 12pt">Crystal Reports for Eclipse is =
a free set=20
of plugins provided by the makers of Crystal Reports, the world's #1 =
Report=20
Designer. Crystal Reports for Eclipse will provide Eclipse developers =
with an=20
embedded report designer as well as a number of development tools to =
assist the=20
developer with building applications.<o:p></o:p></SPAN></FONT></P>
New Roman"=20
size=3D3><SPAN style=3D"FONT-SIZE: =
12pt"><o:p>&nbsp;</o:p></SPAN></FONT></P>
New Roman"=20
size=3D3><SPAN style=3D"FONT-SIZE: 12pt">Below is a list of features =
available with=20
the Crystal Reports for Eclipse product.<o:p></o:p></SPAN></FONT></P>
New Roman"=20
size=3D3><SPAN lang=3DES-PE=20
style=3D"FONT-SIZE: 12pt; mso-ansi-language: =
ES-PE"><o:p>&nbsp;</o:p></SPAN></FONT></P>
<P class=3DMsoNormal style=3D"MARGIN: 0in 0in 0pt"><B=20
style=3D"mso-bidi-font-weight: normal"><U><FONT face=3D"Times New Roman" =
style=3D"FONT-WEIGHT: bold; FONT-SIZE: 12pt; mso-ansi-language: ES-PE; =
mso-bidi-font-weight: normal">Report=20
Design<o:p></o:p></SPAN></FONT></U></B></P>
New Roman"=20
New Roman"=20
<UL style=3D"MARGIN-TOP: 0in" type=3Ddisc>
<LI class=3DMsoNormal=20
style=3D"MARGIN: 0in 0in 0pt; mso-list: l1 level1 lfo1; tab-stops: =
list .5in"><B=20
style=3D"mso-bidi-font-weight: normal"><FONT face=3D"Times New Roman" =
size=3D3><SPAN=20
style=3D"FONT-WEIGHT: bold; FONT-SIZE: 12pt; mso-bidi-font-weight: =
normal">New=20
Report Designer built on the Eclipse Framework </SPAN></FONT></B>- =
built from=20
Component=20
(JRC) engine<o:p></o:p>=20
list .5in"><B=20
size=3D3><SPAN=20
normal">Drag=20
&amp; Drop Report Design</SPAN></FONT></B> - drag objects from the =
Palette or=20
Field Explorer on to the report design pane<o:p></o:p>=20
list .5in"><B=20
size=3D3><SPAN=20
normal">Free=20
form placement <SPAN=20
style=3D"mso-spacerun: yes">&nbsp;</SPAN></SPAN></FONT></B>- don't be =
bound to=20
nesting tables in your report. Drag and drop your report objects =
exactly where=20
you want them to show up on your report<o:p></o:p>=20
list .5in"><B=20
size=3D3><SPAN=20
normal">Auto-generate=20
SQL statements</SPAN></FONT></B> - SQL query is auto-generated based =
on the=20
database fields added to the report<o:p></o:p>=20
list .5in"><B=20
size=3D3><SPAN=20
normal">Design=20
off of POJOs <SPAN style=3D"mso-spacerun: =
yes">&nbsp;</SPAN></SPAN></FONT></B>-=20
drag and drop your Java classes on to your report to use the class =
definition=20
in your report design<o:p></o:p>=20
list .5in"><B=20
size=3D3><SPAN=20
normal">Cross-Tab=20
reports </SPAN></FONT></B>- design cross-tab reports to easily =
visualize=20
grouped data<o:p></o:p>=20
list .5in"><B=20
size=3D3><SPAN=20
normal">Java=20
User Function Library (UFL) support </SPAN></FONT></B>- access =
external Java=20
logic from within your Crystal Reports formulas <o:p></o:p>
list .5in"><B=20
size=3D3><SPAN=20
normal">Multiple=20
Data Source support </SPAN></FONT></B>- use the visual database pane =
to easily=20
create links between multiple data sources<o:p></o:p>=20
list .5in"><B=20
size=3D3><SPAN=20
normal">Integrated=20
Code Assist </SPAN></FONT></B>- Use the built-in Eclipse Code Assist =
feature=20
when building Crystal Reports formulas. <st1:City =
w:st=3D"on"><st1:place=20
w:st=3D"on">Crystal</st1:place></st1:City> syntax will display errors =
and=20
display code assist within the Formulas pane<o:p></o:p></LI></UL>
New Roman"=20
size=3D3><SPAN=20
normal"><o:p><SPAN=20
style=3D"TEXT-DECORATION: =
none">&nbsp;</SPAN></o:p></SPAN></FONT></U></B></P >
size=3D3><SPAN=20
normal">Development=20
Tools<o:p></o:p></SPAN></FONT></U></B></P>
New Roman"=20
New Roman"=20
style=3D"MARGIN: 0in 0in 0pt; mso-list: l2 level1 lfo2; tab-stops: =
list .5in"><st1:City=20
w:st=3D"on"><st1:place w:st=3D"on"><B style=3D"mso-bidi-font-weight: =
normal"><FONT=20
face=3D"Times New Roman" size=3D3><SPAN=20
normal">Crystal</SPAN></FONT></B></st1:place></st1:City ><B=20
style=3D"mso-bidi-font-weight: normal"><SPAN=20
style=3D"FONT-WEIGHT: bold; mso-bidi-font-weight: normal"> Reports Web =
Project</SPAN></B>- this feature will enable developers to create a =
web=20
project which already includes all of the required runtime =
configurations.=20
Additionally, developers can optionally choose to add a sample =
database and=20
reports to the project to get up and running in no time<o:p></o:p>=20
list .5in"><B=20
size=3D3><SPAN=20
normal">JSP=20
Page Wizard</SPAN></FONT></B>-Drag 'n' drop a report onto a JSP page, =
or=20
create a new JSP page via the context menu of a report. This wizard =
will=20
of=20
selected=20
report. Does your report require parameters, do you want to change the =
database at runtime, or export directly to PDF...the wizard will =
generate all=20
of the required code to complete the requested actions, all custom to =
the=20
specific report. You can literally get away with never having to write =
a line=20
of reporting code again<o:p></o:p>=20
list .5in"><B=20
size=3D3><SPAN=20
normal">Java=20
Reporting Component facet</SPAN></FONT></B>-easily add the Crystal =
Reports=20
will=20
never have to worry about ensuring that all your JAR files have been=20
added<o:p></o:p>=20
list .5in"><B=20
size=3D3><SPAN=20
normal">Deployment=20
Assistance</SPAN></FONT></B> - Never have to worry about ensuring the =
proper=20
JDBC drivers are available at runtime. When a report is added to a =
project,=20
the tooling will ensure that the required runtime libraries are =
present=20
built.<o:p></o:p>=20
list .5in"><B=20
size=3D3><SPAN=20
normal">Update=20
your projects with the latest runtime</SPAN></FONT></B>-have you just=20
downloaded a hot fix, but are not too sure if you have already added =
it to an=20
accessed via=20
the Properties Menu of a project to quickly and easily see which file =
versions=20
are currently in your project and compare this with the file versions=20
installed in the tooling. If they are out of synch click the Update =
button to=20
easily update your application to the latest version.<o:p></o:p>=20
list .5in"><B=20
size=3D3><SPAN=20
normal">Global=20
Property Settings</SPAN></FONT></B>-do you find that you are always =
turning=20
off the logo on the viewer, or enabling the refresh button? Well, now=20
Developers can set their global settings for the Crystal Report =
viewers within=20
their workspace preferences. Each time a viewer is added to a JSP page =
these=20
preferences will be honored and the appropriate code modifications =
will be=20
added<o:p></o:p>=20
list .5in"><B=20
size=3D3><SPAN=20
normal">Java=20
User Function Library wizard</SPAN></FONT></B>-this feature enables =
developers=20
organization=20
have a large amount of code already invested into calculating a =
discount=20
ratio? Don't fret, wrap this logic up in a User Function Library using =
this=20
easy wizard and your Crystal Reports files will be able to access this =
same=20
logic <o:p></o:p>
list .5in"><B=20
size=3D3><SPAN=20
normal">Built-in=20
pointers to the Business Objects' Update Site</SPAN></FONT></B>-never =
have to=20
existing=20
Eclipse Update Manager mechanism to check for updates and install them =
automatically. This feature also has built-in rollback capabilities in =
case=20
you opt to go back to a previous version<o:p></o:p>=20
list .5in"><B=20
size=3D3><SPAN=20
Help</SPAN></FONT></B>-Access a complete and robust report designer =
guide as=20
built-in=20
Eclipse Help System<o:p></o:p></LI></UL>
New Roman"=20
New Roman"=20
New Roman"=20
size=3D3><SPAN style=3D"FONT-SIZE: 12pt">On top of all this developers =
will find a=20
large amount of resources (including free forums, video tutorials and =
whitepaper=20
tutorials) available at our Developer Community Site (<A=20
href=3D"http://diamond.businessobjects.com/eclipse/)">http://diamond.busi=
nessobjects.com/eclipse/)</A><o:p></o:p></SPAN></FONT></P >
New Roman"=20
New Roman"=20
New Roman"=20
size=3D3><SPAN style=3D"FONT-SIZE: 12pt">All of these features are =
completely <B=20
style=3D"FONT-WEIGHT: bold; mso-bidi-font-weight: =
normal">FREE</SPAN></B> for=20
developers to download and deploy in production. However, if you need =
more out=20
of the runtime engine, Business Objects also has a Professional version =
of=20
Crystal Reports for Eclipse. This version will be available on the =
Business=20
Objects' e-store and offer the following upgrades for the=20
Developer:<o:p></o:p></SPAN></FONT></P>
New Roman"=20
style=3D"MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo3; tab-stops: =
list .5in"><B=20
size=3D3><SPAN=20
normal">More=20
Power</SPAN></FONT></B> - a runtime engine that provides up to 5X more =
report=20
processing power<o:p></o:p>=20
list .5in"><B=20
size=3D3><SPAN=20
normal">Technical=20
Support</SPAN></FONT></B>- each copy of Crystal Reports for Eclipse=20
contact=20
Business Objects' world class support organization directly<o:p></o:p> =
list .5in"><B=20
size=3D3><SPAN=20
normal">License=20
for Multiple Server Deployments </SPAN></FONT></B>- if you need to =
distribute=20
your application on multiple servers (e.g. web farms, web gardens, =
etc.) then=20
you will require the Professional license<o:p></o:p></LI></UL>
New Roman"=20
New Roman"=20
size=3D3><SPAN style=3D"FONT-SIZE: 12pt">Crystal Reports for Eclipse =
Professional=20
can be purchased from our online store for $495US per server. For more=20
information about our pricing and licensing options check out the =
following <A=20
href=3D" http://diamond.businessobjects.com/system/files/CR4E_Eclipse _Pric=
ingAndLicensing.pdf">article</A>.<o:p></o:p></SPAN></FONT ></P></DIV></BOD=
Y></HTML>
------=_NextPart_000_0050_01C6BE0A.F4F07EB0--
Re: Crystal Reports for Eclipse available for FREE! [message #10415 is a reply to message #10381] Sat, 12 August 2006 15:39 Go to previous message
------=_NextPart_000_006C_01C6BE0C.4FA53570
Would probably help if I told you where you can download it from. :) You =
can view the different installation instructions at the link below:
Installation instructions: http://diamond.businessobjects.com/node/450
Additionally, you can read the Getting Started Guide here: =
http://diamond.businessobjects.com/system/files/CR4E_Getting +Started+Guid=
e.pdf
Finally, for all general Eclipse content you can visit the Business =
Objects Eclipse portal by going to: =
http://www.businessobjects.com/eclipse
<sean.johnson@businessobjects.com> wrote in message =
news:ebla6t$hui$2@utils.eclipse.org...
=20
Eclipse product.
=20
Report Design
=20
=20
b.. Drag & Drop Report Design - drag objects from the Palette or =
Field Explorer on to the report design pane=20
e.. Design off of POJOs - drag and drop your Java classes on to =
your report to use the class definition in your report design=20
grouped data=20
=20
=20
Development Tools
=20
=20
b.. JSP Page Wizard-Drag 'n' drop a report onto a JSP page, or =
create a new JSP page via the context menu of a report. This wizard will =
been added=20
built.=20
version.=20
g.. Java User Function Library wizard-this feature enables =
developers to expose Java logic to their Crystal Reports formulas. Does =
your organization have a large amount of code already invested into =
h.. Built-in pointers to the Business Objects' Update Site-never =
have to worry about whether you have the latest version or not. Use the =
i.. Integrated Help-Access a complete and robust report designer =
guide as well as developer walkthroughs, API docs and Best Practices via =
the built-in Eclipse Help System
=20
=20
=20
=20
All of these features are completely FREE for developers to download =
and deploy in production. However, if you need more out of the runtime =
=20
processing power=20
=20
=3D=20
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Would probably help if I told you where =
you can=20
download it from. :) You can view the different installation =
instructions at the=20
link below:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Installation instructions: <A=20
href=3D"http://diamond.businessobjects.com/node/450">http://diamond.busin=
essobjects.com/node/450</A></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Additionally, you can read the Getting =
Started=20
Guide here: <A=20
href=3D" http://diamond.businessobjects.com/system/files/CR4E_Getting +Star=
ted+Guide.pdf">http://diamond.businessobjects.com/system/files/CR4E_Getti=
ng+Started+Guide.pdf</A></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Finally, for all general Eclipse =
content you can=20
visit the Business Objects Eclipse portal by going to: <A=20
href=3D"http://www.businessobjects.com/eclipse">http://www.businessobject=
s.com/eclipse</A></FONT></DIV>
<DIV>&nbsp;</DIV>
<BLOCKQUOTE dir=3Dltr=20
<DIV>&lt;<A=20
href=3D"mailto:sean.johnson@businessobjects.com">sean.johnson@businessobj=
ects.com</A>&gt;=20
wrote in message <A=20
href=3D"news:ebla6t$hui$2@utils.eclipse.org">news:ebla6t$hui$2@utils.ecli=
pse.org</A>...</DIV>
<DIV>
New Roman"=20
is a free set=20
Report=20
with an=20
assist=20
the developer with building applications.<o:p></o:p></SPAN></FONT></P>
New Roman"=20
New Roman"=20
available=20
with the Crystal Reports for Eclipse =
New Roman"=20
style=3D"mso-bidi-font-weight: normal"><U><FONT face=3D"Times New =
Roman"=20
New Roman"=20
New Roman"=20
list .5in"><B=20
style=3D"mso-bidi-font-weight: normal"><FONT face=3D"Times New =
Roman"=20
size=3D3><SPAN=20
normal">New=20
built=20
from the ground up using Business Objects' award winning Java =
Reporting=20
Component (JRC) engine<o:p></o:p>=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">Drag=20
Palette=20
or Field Explorer on to the report design pane<o:p></o:p>=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">Free=20
style=3D"mso-spacerun: yes">&nbsp;</SPAN></SPAN></FONT></B>- don't =
be bound to=20
exactly=20
where you want them to show up on your report<o:p></o:p>=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
on the=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">Design=20
off of POJOs <SPAN=20
style=3D"mso-spacerun: yes">&nbsp;</SPAN></SPAN></FONT></B>- drag =
and drop=20
your Java classes on to your report to use the class definition in =
your=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
visualize=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">Java=20
external Java=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">Multiple=20
to=20
easily create links between multiple data sources<o:p></o:p>=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
feature=20
w:st=3D"on">Crystal</st1:place></st1:City> syntax will display =
errors and=20
New Roman"=20
Roman"=20
size=3D3><SPAN=20
Roman"=20
size=3D3><SPAN=20
New Roman"=20
New Roman"=20
normal"><FONT=20
style=3D"FONT-WEIGHT: bold; mso-bidi-font-weight: normal"> Reports =
Web=20
web=20
configurations.=20
database and=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">JSP=20
Page Wizard</SPAN></FONT></B>-Drag 'n' drop a report onto a JSP =
page, or=20
will=20
provide developers with a dialog page allowing them to choose a =
number of=20
selected=20
report. Does your report require parameters, do you want to change =
the=20
generate=20
all of the required code to complete the requested actions, all =
custom to=20
the specific report. You can literally get away with never having to =
write a=20
line of reporting code again<o:p></o:p>=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">Java=20
Reports=20
will=20
never have to worry about ensuring that all your JAR files have been =
added<o:p></o:p>=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
Assistance</SPAN></FONT></B> - Never have to worry about ensuring =
the proper=20
project,=20
present=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">Update=20
your projects with the latest runtime</SPAN></FONT></B>-have you =
just=20
it to=20
accessed=20
via the Properties Menu of a project to quickly and easily see which =
file=20
versions are currently in your project and compare this with the =
file=20
versions installed in the tooling. If they are out of synch click =
the Update=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">Global=20
turning=20
off the logo on the viewer, or enabling the refresh button? Well, =
now=20
viewers=20
within their workspace preferences. Each time a viewer is added to a =
JSP=20
page these preferences will be honored and the appropriate code=20
modifications will be added<o:p></o:p>=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">Java=20
User Function Library wizard</SPAN></FONT></B>-this feature enables=20
developers to expose Java logic to their Crystal Reports formulas. =
Does your=20
calculating a=20
discount ratio? Don't fret, wrap this logic up in a User Function =
Library=20
using this easy wizard and your Crystal Reports files will be able =
to access=20
this same logic <o:p></o:p>
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">Built-in=20
pointers to the Business Objects' Update =
Site</SPAN></FONT></B>-never have=20
existing=20
Eclipse Update Manager mechanism to check for updates and install =
them=20
automatically. This feature also has built-in rollback capabilities =
in case=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
guide as=20
built-in=20
New Roman"=20
New Roman"=20
New Roman"=20
will find a=20
large amount of resources (including free forums, video tutorials and=20
whitepaper tutorials) available at our Developer Community Site (<A=20
New Roman"=20
New Roman"=20
New Roman"=20
completely <B=20
more out=20
of the runtime engine, Business Objects also has a Professional =
version of=20
Business=20
New Roman"=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">More=20
Power</SPAN></FONT></B> - a runtime engine that provides up to 5X =
more=20
report processing power<o:p></o:p>=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
contact=20
Business Objects' world class support organization =
directly<o:p></o:p>=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">License=20
for Multiple Server Deployments </SPAN></FONT></B>- if you need to=20
gardens, etc.) then you will require the Professional=20
New Roman"=20
New Roman"=20
Professional=20
can be purchased from our online store for $495US per server. For more =
following <A=20
ingAndLicensing.pdf">article</A>.<o:p></o:p></SPAN></FONT ></P></DIV></BLO=
CKQUOTE></BODY></HTML>
------=_NextPart_000_006C_01C6BE0C.4FA53570--
Re: Crystal Reports for Eclipse available for FREE! [message #562489 is a reply to message #10381] Sat, 12 August 2006 15:39 Go to previous message
e.pdf
=20
Eclipse product.
=20
Report Design
=20
=20
grouped data=20
=20
=20
Development Tools
=20
=20
been added=20
built.=20
version.=20
=20
=20
=20
=20
=20
processing power=20
=20
=3D=20
<STYLE></STYLE>
</HEAD>
you can=20
Started=20
Guide here: <A=20
content you can=20
<DIV>&nbsp;</DIV>
<DIV>&lt;<A=20
ects.com</A>&gt;=20
<DIV>
New Roman"=20
is a free set=20
Report=20
with an=20
assist=20
New Roman"=20
New Roman"=20
available=20
New Roman"=20
Roman"=20
New Roman"=20
New Roman"=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">New=20
built=20
Reporting=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">Drag=20
Palette=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">Free=20
be bound to=20
exactly=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
on the=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">Design=20
and drop=20
your=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
visualize=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">Java=20
external Java=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">Multiple=20
to=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
feature=20
errors and=20
New Roman"=20
Roman"=20
size=3D3><SPAN=20
Roman"=20
size=3D3><SPAN=20
New Roman"=20
New Roman"=20
normal"><FONT=20
Web=20
web=20
configurations.=20
database and=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">JSP=20
page, or=20
will=20
number of=20
selected=20
the=20
generate=20
custom to=20
write a=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">Java=20
Reports=20
will=20
added<o:p></o:p>=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
the proper=20
project,=20
present=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">Update=20
just=20
it to=20
accessed=20
file=20
file=20
the Update=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">Global=20
turning=20
now=20
viewers=20
JSP=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">Java=20
Does your=20
calculating a=20
Library=20
to access=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">Built-in=20
existing=20
them=20
in case=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
guide as=20
built-in=20
New Roman"=20
New Roman"=20
New Roman"=20
will find a=20
New Roman"=20
New Roman"=20
New Roman"=20
completely <B=20
more out=20
version of=20
Business=20
New Roman"=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">More=20
more=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
contact=20
list .5in"><B=20
Roman"=20
size=3D3><SPAN=20
normal">License=20
New Roman"=20
New Roman"=20
Professional=20
following <A=20
Previous Topic:Crystal Reports for Eclipse available for FREE!
Next Topic:Blueprint Software Modeler, one of the first commercial UML 2.1 modeling tools on the market
Current Time: Thu Jul 24 11:14:56 EDT 2025
Powered by FUDForum. Page generated in 0.03938 seconds
