Deploying a RAP application [message #113661] |
Wed, 26 November 2008 10:25  |
I am having a hard time trying to deploy a RAP application. I am following
the instructions of your tutorial on WAR deployment but I just don't get
beyond the point where the webappBuilder.xml is been executed using an. It
creates the build directory, but in the eclipse folder that is in there
there is just the configuration folder. The other two folder plugins and
features are missing. I don't know whats going wrong.
Thanks for your help in advance
Gunnar Wurl
Re: Deploying a RAP application [message #113775 is a reply to message #113763] |
Thu, 27 November 2008 05:39   |
No, I did not. I had a quick look now at the property of the demo but it
is already set to the correct feature, which I downloaded from the cvs.
Markus Schnelle wrote:
> Did you adjust the feature property in webappBuilder.xml to the project
> in which the feature.xml is?
> greeting, markus
> Gunnar Wurl wrote:
>> Yes, this option is selected, and there are no errors when running the
>> script.
>> Ivan Furnadjiev wrote:
>>> Hi Gunnar,
>>> did you select the "Run in the same JRE as the workspace" from the JRE
>>> tab of "Run Ant.." configuration? This is necessary for
>>> pdeExportFeatures ant target to work.
>>> Best,
>>> Ivan
>>> Gunnar Wurl wrote:
>>>> Hi,
>>>> following the instructions of your tutorial on WAR deployment but I
>>>> just don't get beyond the point where the webappBuilder.xml is been
>>>> executed using an. It creates the build directory, but in the eclipse
>>>> folder that is in there there is just the configuration folder. The
>>>> other two folder plugins and features are missing. I don't know whats
>>>> going wrong.
>>>> Gunnar Wurl
Re: Deploying a RAP application [message #113820 is a reply to message #113775] |
Thu, 27 November 2008 08:23  |
Thanks for trying to help me. I tested a little bit around with the
options of the feature, removed the rapdemo from the plugins and added it
again and set some platform options, let compute the dependencies and now
it works. I am not sure what did the trick but now it works.
Thanks again
Gunnar
>> greeting, markus
>>> script.
>>>> Hi Gunnar,
>>>> Best,
>>>> Ivan
>>>> Gunnar Wurl wrote:
>>>>> Hi,
>>>>> going wrong.
>>>>> Gunnar Wurl
FUDForum. Page generated in 0.46239 seconds
