Re: All ObjectIds of Heap dump [message #10393 is a reply to message #10360] |
Fri, 15 May 2009 02:57  |
Programatically or somehow in the GUI? Programatically you can do this:
You can use the ISnapshot.getSnapshotInfo().getNumberOfObjects() to get
the count of objects. The IDs we give to the objetcts start from 0 and are
sequential - so you just have to iterate from 0 to "count"
If you want to see the object addresses, you can use the in your iteration.
ISnapshot.mapIdToAddress(int objectId)
Just a note - using the object IDs in your queries will work much faster
that using the object addresses.
Hope this helps.
Krum
M.S.Alavi wrote:
> I want to know how I can get all the object IDs of all objects in the
> snapshot.
> any Idea?
> Mohammad
FUDForum. Page generated in 0.04392 seconds
