Home » Modeling » BPEL Designer » Trouble with ReconciliationHelper
Trouble with ReconciliationHelper [message #10339] Wed, 05 March 2008 14:37
Originally posted by: hanyu.xiao.gmail.com
Could someone tell me how to make the following snippet work?
Process bpelProcess = BPELFactory.eINSTANCE.createProcess();
Variables variables = BPELFactory.eINSTANCE.createVariables();
Variable variable = BPELFactory.eINSTANCE.createVariable();
variable.setName("foo");
XSDSimpleTypeDefinition type =
XSDFactory.eINSTANCE.createXSDSimpleTypeDefinition();
type.setName("xsd:string");
variable.setType(type);
variables.getChildren().add(variable);
bpelProcess.setVariables(variables);
When executing to the second line from the bottom, I’d get this exception:
Exception in thread "main" java.lang.NullPointerException
org.eclipse.bpel.model.util.ReconciliationHelper.patchParent Element(ReconciliationHelper.java:481)
org.eclipse.bpel.model.impl.VariablesImpl.adoptContent(Varia blesImpl.java:176)
org.eclipse.wst.wsdl.internal.impl.WSDLElementImpl.eNotify(W SDLElementImpl.java:392)
org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(E coreEList.java:249)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:300)
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:6 26)
It seems that ReconciliationHelper assumes that "variables" has a
container, which won’t be true until the last line is called. But if I
move the last line to the third, like this:
ReconciliationHelper will throw another exception:
org.eclipse.bpel.model.util.ReconciliationHelper.getBPELChil dElementByLocalName(ReconciliationHelper.java:506)
This time ReconciliationHelper assumed that the BPEL model has an
associated XML element, which is again not correct in this case.
Maybe I’m just not using the BPEL models correctly, but this code used
to work with the M2 build. What would I need to do to fix this in M3?
Thanks in advance,
Hanyu
Previous Topic:problem in invoking of a web service
Next Topic:AEP Engine doesn't deploy correctly
Current Time: Thu Aug 21 15:14:26 EDT 2025
Powered by FUDForum. Page generated in 0.03761 seconds
