Home » Eclipse Projects » Nebula » [PATCH] DateTimeCellEditor
[PATCH] DateTimeCellEditor [message #10330] Thu, 31 August 2006 09:38 Go to next message
Originally posted by: orestis.orestis.gr
I needed to create a JFace CellEditor that uses the CDatePicker widget.
Here is the code in case someone else needs it. It is only tested on
Windows though I suppose it doesn't matter. It assumes that the values
passed are java.util.Date, under different input it will blow up with
ClassCastException. If this gets added to the CVS I'll clean it up a bit.
Jeremy please let me know if this a stupid way to do stuff.
import java.util.Date;
import org.aspencloud.widgets.ACW;
import org.aspencloud.widgets.cdatepicker.CDatepickerCombo;
import org.eclipse.jface.viewers.CellEditor;
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Table;
public class DateTimeCellEditor extends CellEditor
Date value;
private CDatepickerCombo cdc;
private int acwstyle;
public DateTimeCellEditor(Table table2,int acwstyle)
super(table2);
this.acwstyle = acwstyle;
protected Control createControl(Composite parent)
Composite comp = new Composite(parent, SWT.NONE);
cdc = new CDatepickerCombo(comp, ACW.DROP_DOWN | acwstyle);
return cdc;
protected Object doGetValue()
return cdc.getCDatepicker().getSelection();
protected void doSetFocus()
cdc.setSelection(value);
cdc.popUp(true);
protected void doSetValue(Object theValue)
this.value = (Date) theValue;
Re: [PATCH] DateTimeCellEditor [message #10363 is a reply to message #10330] Thu, 31 August 2006 09:43 Go to previous messageGo to next message
> Date value;
> super(table2);
> @Override
> return cdc;
> @Override
> @Override
> cdc.popUp(true);
> @Override
Ooops. The CDatePicker widget isn't in nebula, is it ? Sorry if I
confused someone. This is for an ordinary JFace TableViewer, not for
CTableTree (maybe it can be used too - I don't know).
Orestis
Re: [PATCH] DateTimeCellEditor [message #10462 is a reply to message #10363] Fri, 01 September 2006 11:19 Go to previous message
Orestis,
Thanks for sharing your code, though you're right that CDatepicker is
not a part of Nebula - perhaps it should be... time permitting, I'll try
to start some discussion on a Nebula "Calendar Widget Suite" on the
developer list.
In the mean-time, if you would like to submit your code (the whole file
- with copyright notice, licensed under EPL) via a Feature Request on
Sourceforge I'd like to include it with the distribution of
CDatepicker/Combo.
> Orestis
Re: [PATCH] DateTimeCellEditor [message #564570 is a reply to message #10330] Thu, 31 August 2006 09:43 Go to previous message
> Date value;
> super(table2);
> @Override
> return cdc;
> @Override
> @Override
> cdc.popUp(true);
> @Override
Orestis
Re: [PATCH] DateTimeCellEditor [message #564642 is a reply to message #10363] Fri, 01 September 2006 11:19 Go to previous message
Orestis,
developer list.
CDatepicker/Combo.
> Orestis
Previous Topic:embedding GEF/draw2 viewer/figures in table/tree cell
Next Topic:embedding GEF/draw2 viewer/figures in table/tree cell
Current Time: Tue Jul 22 01:38:51 EDT 2025
Powered by FUDForum. Page generated in 0.03350 seconds
