Home » Eclipse Projects » GEF » Parent edit part selection
Parent edit part selection [message #113048] Wed, 21 January 2004 12:50 Go to next message
How do I go about selecting the parent of an edit part if a child is
selected. For example, in the logic example, how would I select the
circuit when an element within the circuit is selected (i.e. I want to see
the handles for both the circuit and the contained element).
Thanks.
James
Re: Parent edit part selection [message #113092 is a reply to message #113048] Wed, 21 January 2004 13:17 Go to previous messageGo to next message
ALT+UP
For all of the details, see GraphicalViewerKeyHandler
"James Willans" <jwillans@cs.york.ac.uk> wrote in message
news:bume4p$c6d$1@eclipse.org...
> Thanks.
> James
Re: Parent edit part selection [message #113103 is a reply to message #113092] Wed, 21 January 2004 13:32 Go to previous messageGo to next message
I should have been more explicit: how do I do this programatically when
the child is selected by the user?
James
Randy Hudson wrote:
> ALT+UP
> > Thanks.
> > James
Re: Parent edit part selection [message #113126 is a reply to message #113103] Wed, 21 January 2004 15:21 Go to previous messageGo to next message
Originally posted by: brian.fernandes.codito.com
override getDragTracker for the childs EditPart to return your own Tracker,
mostly extended from SelectEditPartTracker. This tracker will also select
the parents EditPart.
Have a look at SelectEditPartTracker, implementation should be pretty
straight forward.
All the best,
Brian.
Re: Parent edit part selection [message #113150 is a reply to message #113126] Wed, 21 January 2004 16:37 Go to previous messageGo to next message
Brian,
Thanks - very helpful, although I'm still not there yet. I've constructed
my own tracker which extends SelectEditPartTracker and I can force the
selection of the parent's edit part (in the tracker's constructor) using
"ep.setSelected(1)" where ep is the edit part. This works, but I'm aware
that it is not the correct way to do it (the API says that this method
should only be called by the edit part's viewer). Moreover it doesn't
loose the selection when some other edit part is selected.
I've tried using the following approach:
EditPartViewer viewer = owner.getViewer();
viewer.select(owner);
where "owner" is the owning edit part of the part owning the tracker, but
that doesn't work. Any advice on this, and loosing the selection upon
alternative selection, much appreciated.
James
> straight forward.
> All the best,
> Brian.
Re: Parent edit part selection [message #113161 is a reply to message #113150] Wed, 21 January 2004 16:51 Go to previous messageGo to next message
You may want to try calling
"viewer.appendSelection(getSourceEditPart().getParent())" in
performSelection(). Look in this method for the current way selection works.
news:bumrf1$tmq$1@eclipse.org...
> Brian,
> James
Tracker,
select
> > straight forward.
> > All the best,
> > Brian.
Re: Parent edit part selection [message #113189 is a reply to message #113161] Thu, 22 January 2004 06:28 Go to previous message
Whitney,
Many thanks - that worked well.
James
> > Brian,
> > James
> Tracker,
> select
> > > straight forward.
> > > All the best,
> > > Brian.
Previous Topic:GEF Session Feb 5th at EclipseCon
Next Topic:Connections with different Colors
Current Time: Tue Jul 15 21:55:47 EDT 2025
Powered by FUDForum. Page generated in 0.11352 seconds
