Home » Newcomers » Newcomers » -clean option where / how do I find it ?
-clean option where / how do I find it ? [message #112923] Fri, 28 October 2005 11:22 Go to next message
User guide makes several mentions of running -clean after installing a
plug-in but there is no obvious answer as to ho to find it and run it - even
the archives says that this is 'not documented' and then refers a reader off
to an external source.
Clearly this is a useful tool but no where does it explain how to use it -
any ideas ?
cheers Vince
Re: -clean option where / how do I find it ? [message #112939 is a reply to message #112923] Fri, 28 October 2005 11:30 Go to previous messageGo to next message
Vince,
-clean is a command line option that can be specified when launching the
eclipse executable. Depending on what operating system you have you
should be able to get to a command line (Terminal on Linux/OS X, Command
Prompt on Windows), navigate to the eclipse directory, and enter
"eclipse -clean"
Hope this helps,
- Jeff
Vince Jacobs wrote:
> Hi
> any ideas ?
> cheers Vince
Re: -clean option where / how do I find it ? [message #112974 is a reply to message #112923] Fri, 28 October 2005 13:31 Go to previous message
Originally posted by: zifu.yang.gmail.com
I guess, for example, in Windows, you open a command window and
go to the Eclipse directory and execute:
eclipse -clean
"Vince Jacobs" <vincej@shaw.ca> wrote in message
news:djtfof$e3h$1@news.eclipse.org...
> Hi
> even the archives says that this is 'not documented' and then refers a
> reader off to an external source.
> any ideas ?
> cheers Vince
Previous Topic:Help with debugging
Next Topic:Insert into AS/400 file
Current Time: Tue Jul 15 07:02:48 EDT 2025
Powered by FUDForum. Page generated in 0.28416 seconds
