Home » Language IDEs » C / C++ IDE (CDT) » Problem extending Toolchain
Problem extending Toolchain [message #112834] Wed, 28 July 2004 12:29
Originally posted by: tobias.klotz.draeger.com
I followed the tutorial in the "Managed Build System Extensibility Doc"
and had some problems (configuration: Eclipse 3, CDT 2):
I followed chapter 5 up to point 5.6 (with the difference of adding a real
tool instead of ccc), checked it using the debugger but nothing happens.
On seeing the errorlog I got an exception as follows:
org.eclipse.cdt.managedbuilder.internal.core.GeneratedMakefi leBuilder.build(GeneratedMakefileBuilder.java:237)
org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:564)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:615)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:157)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:249)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:202)
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:229)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:232)
org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:268)
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:297)
org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:155)
org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:212)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
Did I miss some configuration or is there a problem in the Makefile
Generator? Any hint for this?
Tobias
Previous Topic:Syntax Coloring with .C files
Next Topic:[CDT newbie] Creating Managed C++ project using CDT 2.0
Current Time: Mon Jul 21 20:05:46 EDT 2025
Powered by FUDForum. Page generated in 0.03858 seconds
