Home » Eclipse Projects » Eclipse Platform » Text selection question
Text selection question [message #10289] Thu, 24 April 2003 09:59 Go to next message
Originally posted by: wehbymj.hotmail.com
How do I determine what text the user has highlighted when they click on a
button I added to the toolbar? I really only care about the java editor.
Re: Text selection question [message #10455 is a reply to message #10289] Thu, 24 April 2003 10:08 Go to previous messageGo to next message
>Thanks
Normally you do not have to ask for the selection but should store it
when IActionDelegate.selectionChanged gets called on your action delegate.
Dani
Re: Text selection question [message #10683 is a reply to message #10455] Thu, 24 April 2003 10:45 Go to previous messageGo to next message
Here is what I am trying to get too. I want to have a button in the
toolbar. I want the user to be able to highlight some java code and hit the
button. Once the button is hit, I want to determine what is highlighted,
modify it and display it in a dialog box.
I am using eclipse 2.1 and I used the Hello World template to get me
started. I have been reading api documents and what not. I came across the
IActionDelegate stuff. Why would the frame work call my selectionChanged
method if the action is called after the text has been selected. So, the
text isn't being highlighted after the button, but before.
Maybe someone could point out a article or a list of classes in the api
documentation for me to read.
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:b88r15$2v2$1@rogue.oti.com...
a
> >Thanks
> Dani
Re: Text selection question [message #13069 is a reply to message #10683] Thu, 24 April 2003 15:11 Go to previous messageGo to next message
Originally posted by: genadyb.inter.net.il
It calls your "selectionChanged" method each time the selection is changed.
The other way is to check what is the current editor and then if it is a
text editor, check its selection.
Genady
> Thanks
> a
>>>Thanks
>>Dani
Re: Text selection question [message #13126 is a reply to message #10683] Thu, 24 April 2003 15:13 Go to previous messageGo to next message
Read the documentation for the org.eclipse.ui.editorActions extension point.
Jeff
Re: Text selection question [message #13156 is a reply to message #13069] Thu, 24 April 2003 15:18 Go to previous messageGo to next message
Thanks for your reply. I believe I want the second option. So, if the run
method is being called when the button is pushed, how do I get the current
editor and see what type it is. I have a lot of java experience, but no
eclipse experience, so you can be tech. in your reply.
public class SampleAction implements IWorkbenchWindowActionDelegate {
private IWorkbenchWindow window;
public SampleAction() {
public void run(IAction action) {
"Genady" <genadyb@inter.net.il> wrote in message
news:b89ctj$jni$1@rogue.oti.com...
changed.
> Genady
the
highlighted,
the
selectionChanged
the
> > Thanks
on
> > a
editor.
> >>>Thanks
delegate.
> >>Dani
Re: Text selection question [message #13320 is a reply to message #13156] Thu, 24 April 2003 15:51 Go to previous messageGo to next message
Here is an excerpt from something I wrote:
public class CompletionAction implements IWorkbenchWindowActionDelegate {
/** The window where the action appears */
private IWorkbenchWindow activeWindow = null;
public void init(IWorkbenchWindow window) {
activeWindow = window;
* Run the action. First check whether we can continue
* the previous completion operation. If not,
* create new completion operation and invoke it.
public void run(IAction proxyAction) {
IEditorPart editor = activeWindow.getActivePage().getActiveEditor();
ITextEditor textEditor;
if (editor instanceof ITextEditor) {
textEditor = (ITextEditor)editor;
} else {
activeWindow.getShell().getDisplay().beep();
return;
ITextSelection sel =
((ITextSelection)textEditor.getSelectionProvider().getSelect ion());
Genady
> Thanks
> changed.
>>Genady
> the
> highlighted,
> the
> selectionChanged
> the
>>>Thanks
> on
>>>a
> editor.
>>>>>Thanks
> delegate.
>>>>Dani
Re: Text selection question [message #13407 is a reply to message #10683] Thu, 24 April 2003 16:06 Go to previous message
Originally posted by: knut_radloff.oti.com
The article "Contributing Actions to the Eclipse Workbench" on http://www.eclipse.org/articles/index.html is one of my favorites and
is a must read if you want to add any kind of action.
As an alternative to recording the selection as it changes via selectionChanged you can store the active editor set in
IEditorActionDelegate.setActiveEditor and get the selection via the editor part/editor site/selection provider when you need it.
Knut
"Mark Wehby" <wehbymj@hotmail.com> wrote in message news:b88t6c$501$1@rogue.oti.com...
> Thanks
> a
> > >Thanks
> > Dani
Previous Topic:Linking from a feature.xml to help content
Next Topic:java source
Current Time: Tue Jul 08 22:42:09 EDT 2025
Powered by FUDForum. Page generated in 0.06268 seconds
