Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Too many join - issue with the HibernateMapping file
Re: Too many join - issue with the HibernateMapping file [message #112799 is a reply to message #112746] |
Wed, 20 February 2008 19:23 |
Martin Taal Messages: 5468 Registered: July 2009 |
Hi Yigal,
Ok, can you send me the ecore (directly by email)?
gr. Martin
Yigal wrote:
> I have a very complex EMF module (over 150 classes). All classes in the
> model are extend of one of two basic types: Part or Part_Relation.
> Part is an abstract class that identifies a generic part. Part_relation
> associates part to other parts.
> Example: A car engine is a "Part" of the Car assemble. The engine has
> many parts in side it. Those parts are grouped by functionality, like
> moving parts, common parts, and etc. So I have Engine_MovingPart_Rel
> that relates any moving parts to the engine.
> Basic relation:
> | | Aggregation | | Association | |
> | Engine |-------------->| Eng_Rel |------------->| Part |
> | |* 1| |1 1| |
> This way I can associate different parts to the engine.
> The Engine_MovingPart_Rel extends the Eng_Rel and adds additional
> attributes that makes the assemble.
> | Engine |-------------->| Eng_MovePart------------->| Piston |
> | |* 1| Rel |1 1| |
> Piston expands "Part".
> | Piston |-------------->| Piston_Rel |------------->| PistonRings |
> | |* 1| |1 1| |
> (and so on and on)
> I generated the Hibernate mapping file using the Join option.
> When I create a HibernateResource and load an Engine, and want to LAZY
> load all the different Engine_REL, I get over 69 joins that is an over
> flow in mySql and causes an exception (fail). I investigated the SQL
> commands and found that hibernate wants to load the entire model and
> does not do lazy loading of the relationships. The SQL join all the
> relations with all the parts and relations between those parts and other
> parts.
> I tried the following:
> 1. I put the @Proxy attribute on the "Piston" parts, the result was
> combined tables of all abstract classes and database table only on non
> abstract classes (duplication of data). But the issue was still there
> and the join fails with more then 61 joins)
> 2. I tries to use the cascade fetch(Lazy) annotation. Did not help.
> Currently I use the fist option of generating the the hibernate mapping
> file,but that creates only TWO tables in the Database with all
> attributes in them and the need for over 64 indexes which is not support
> either. The join issue does not exists and I can run my application.
> However a flat database is not acceptable and I have no indexes.
> Any solution?
> Thanks
> Yigal
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Too many join - issue with the HibernateMapping file [message #112825 is a reply to message #112799] |
Wed, 20 February 2008 19:56 |
Yigal Spinner Messages: 127 Registered: July 2009 |
Hi Martine,
Sorry but the eCore is an Intellectual Property of my company and can
not be distributed with out an NDA.
The sample below is not the real eCore but a close enough approximation.
I was hopping it would be enough to get some directions to solve my issue.
Yigal
Martin Taal wrote:
> Hi Yigal,
> gr. Martin
>> the model are extend of one of two basic types: Part or Part_Relation.
>> Part_relation associates part to other parts.
>> has many parts in side it. Those parts are grouped by functionality,
>> like moving parts, common parts, and etc. So I have
>> Engine_MovingPart_Rel that relates any moving parts to the engine.
>> Basic relation:
>> | |* 1| |1 1| |
>> | |* 1| Rel |1 1| |
>> | |* 1| |1 1| |
>> (and so on and on)
>> other parts.
>> mapping file,but that creates only TWO tables in the Database with all
>> support either. The join issue does not exists and I can run my
>> application.
>> Any solution?
>> Thanks
>> Yigal
Re: Too many join - issue with the HibernateMapping file [message #112851 is a reply to message #112825] |
Wed, 20 February 2008 21:44 |
Hi Yigal,
Hmm it is the easiest if I can reproduce the issue (which afaics is mainly a lazy-loading issue)
with a small test model.
What was not completely clear from the model why the eng_rel to part is a 1-1 (1 on both sides), I
would have expected a model like this:
Engine (1)------(*) Eng_Rel (*) -------(1) Part
based on your description. So therefore my confusion.
Does this maybe apply to your situation (minOccurs>0):
http://www.elver.org/hibernate/hibernateresources.html#Valid ation
Lazy loading works in Teneo I have multiple testcases covering this. So it must be something related
to your model (and how Teneo handles it ofcourse). Can you make a small fake subset of your model
which shows the same (eager loading) behavior? Which can be send to me without nda.
gr. Martin
Yigal wrote:
> Hi Martine,
> Yigal
> Martin Taal wrote:
>> Hi Yigal,
>> gr. Martin
>>> Basic relation:
>>> | |* 1| |1 1| |
>>> | |* 1| Rel |1 1| |
>>> | |* 1| |1 1| |
>>> (and so on and on)
>>> LAZY load all the different Engine_REL, I get over 69 joins that is
>>> an over flow in mySql and causes an exception (fail). I investigated
>>> the SQL commands and found that hibernate wants to load the entire
>>> model and does not do lazy loading of the relationships. The SQL
>>> join all the relations with all the parts and relations between those
>>> parts and other parts.
>>> non abstract classes (duplication of data). But the issue was still
>>> there and the join fails with more then 61 joins)
>>> all attributes in them and the need for over 64 indexes which is not
>>> application.
>>> Any solution?
>>> Thanks
>>> Yigal
The Netherlands
Re: Too many join - issue with the HibernateMapping file [message #116116 is a reply to message #112851] |
Thu, 27 March 2008 12:27 |
Hi Martin,
I figured out the issue. The issue was with hibernate options.
There is an option called MAX_FETCH_DEPTH and the default is set to 3.
In my module a level three at the point of collecting all parts causes
too many join tables. In any case, I want to do lazy loading, so I set
the option to level 0 and now it works fine.
Yigal
Martin Taal wrote:
> Hi Yigal,
> mainly a lazy-loading issue) with a small test model.
> a 1-1 (1 on both sides), I would have expected a model like this:
> it must be something related to your model (and how Teneo handles it
> ofcourse). Can you make a small fake subset of your model which shows
> gr. Martin
> Yigal wrote:
>> Hi Martine,
>> issue.
>> Yigal
>> Martin Taal wrote:
>>> Hi Yigal,
>>> gr. Martin
>>>> Basic relation:
>>>> | |* 1| |1 1| |
>>>> | |* 1| Rel |1 1| |
>>>> | |* 1| |1 1| |
>>>> (and so on and on)
>>>> investigated the SQL commands and found that hibernate wants to load
>>>> the entire model and does not do lazy loading of the relationships.
>>>> The SQL join all the relations with all the parts and relations
>>>> between those parts and other parts.
>>>> application.
>>>> Any solution?
>>>> Thanks
>>>> Yigal
Re: Too many join - issue with the HibernateMapping file [message #116129 is a reply to message #116116] |
Thu, 27 March 2008 12:44 |
Hi Yigal,
Thanks for the update, I'll add this to the troubleshooting section of the docs.
gr. Martin
Yigal wrote:
> Hi Martin,
> Thanks
> Yigal
> Martin Taal wrote:
>> Hi Yigal,
>> is a 1-1 (1 on both sides), I would have expected a model like this:
>> So it must be something related to your model (and how Teneo handles
>> it ofcourse). Can you make a small fake subset of your model which
>> without nda.
>> gr. Martin
>> Yigal wrote:
>>> Hi Martine,
>>> issue.
>>> Yigal
>>> Martin Taal wrote:
>>>> Hi Yigal,
>>>> gr. Martin
>>>>> in the model are extend of one of two basic types: Part or
>>>>> Part_Relation.
>>>>> functionality, like moving parts, common parts, and etc. So I have
>>>>> Basic relation:
>>>>> | |* 1| |1 1| |
>>>>> | |* 1| Rel |1 1| |
>>>>> | |* 1| |1 1| |
>>>>> (and so on and on)
>>>>> load the entire model and does not do lazy loading of the
>>>>> relationships. The SQL join all the relations with all the parts
>>>>> and relations between those parts and other parts.
>>>>> not support either. The join issue does not exists and I can run
>>>>> my application.
>>>>> Any solution?
>>>>> Thanks
>>>>> Yigal
The Netherlands
Re: Too many join - issue with the HibernateMapping file [message #615527 is a reply to message #112746] |
Hi Yigal,
gr. Martin
> Basic relation:
> | |* 1| |1 1| |
> | |* 1| Rel |1 1| |
> | |* 1| |1 1| |
> (and so on and on)
> parts.
> Any solution?
> Thanks
> Yigal
The Netherlands
Re: Too many join - issue with the HibernateMapping file [message #615529 is a reply to message #112799] |
Hi Martine,
Yigal
Martin Taal wrote:
> Hi Yigal,
> gr. Martin
>> Basic relation:
>> | |* 1| |1 1| |
>> | |* 1| Rel |1 1| |
>> | |* 1| |1 1| |
>> (and so on and on)
>> other parts.
>> application.
>> Any solution?
>> Thanks
>> Yigal
Re: Too many join - issue with the HibernateMapping file [message #615531 is a reply to message #112825] |
Hi Yigal,
gr. Martin
Yigal wrote:
> Hi Martine,
> Yigal
> Martin Taal wrote:
>> Hi Yigal,
>> gr. Martin
>>> Basic relation:
>>> | |* 1| |1 1| |
>>> | |* 1| Rel |1 1| |
>>> | |* 1| |1 1| |
>>> (and so on and on)
>>> application.
>>> Any solution?
>>> Thanks
>>> Yigal
The Netherlands
Re: Too many join - issue with the HibernateMapping file [message #616008 is a reply to message #112851] |
Hi Martin,
Yigal
Martin Taal wrote:
> Hi Yigal,
> gr. Martin
> Yigal wrote:
>> Hi Martine,
>> issue.
>> Yigal
>> Martin Taal wrote:
>>> Hi Yigal,
>>> gr. Martin
>>>> Basic relation:
>>>> | |* 1| |1 1| |
>>>> | |* 1| Rel |1 1| |
>>>> | |* 1| |1 1| |
>>>> (and so on and on)
>>>> application.
>>>> Any solution?
>>>> Thanks
>>>> Yigal
Re: Too many join - issue with the HibernateMapping file [message #616009 is a reply to message #116116] |
Hi Yigal,
gr. Martin
Yigal wrote:
> Hi Martin,
> Thanks
> Yigal
> Martin Taal wrote:
>> Hi Yigal,
>> without nda.
>> gr. Martin
>> Yigal wrote:
>>> Hi Martine,
>>> issue.
>>> Yigal
>>> Martin Taal wrote:
>>>> Hi Yigal,
>>>> gr. Martin
>>>>> Part_Relation.
>>>>> Basic relation:
>>>>> | |* 1| |1 1| |
>>>>> | |* 1| Rel |1 1| |
>>>>> | |* 1| |1 1| |
>>>>> (and so on and on)
>>>>> my application.
>>>>> Any solution?
>>>>> Thanks
>>>>> Yigal
The Netherlands
Current Time: Fri Apr 26 16:26:00 GMT 2024
Powered by FUDForum. Page generated in 0.03340 seconds
