[p2] no SDKProfile generated when building eclipse from source [message #112058] |
Fri, 13 June 2008 12:28  |
I am trying to build eclipse from source, but the result does not have
any SDKProfile or generated p2 metadata. The way I understand it, the
build script should be generating the p2 metadata. Is this a correct
assumption? If so, where in the eclipse build scripts is the call to
generate the metadata or where is the configuration set for generating
this metadata? I see the generate.p2.metadata targets in the
assemble.org.eclipse.sdk.os.win.arch.xml and
package.org.eclipse.sdk.os.win.arch.xml files but I do not see how the
if="generate.p2.metadata" conditional is ever set.
Thanks for any help.
-----Tim------
Re: [P2] no per-user bundles/source.info created when starting multi-user Eclipse [message #115829 is a reply to message #115762] |
Wed, 06 August 2008 18:52  |
Hi James,
Good to put a name with a handle. I had not noticed your email address....
Anyway, this is an interesting use case, and you are quite right that I
was running eclipse and the p2 director as the same user. I will keep
an eye out for this.
Thanks again.
----Tim-----
James Le Cuirot wrote:
> On Wed, 06 Aug 2008 06:24:35 -0700
> Tim Myer <timezra@gmail.com> wrote:
>> Someone left a great comment on my blog yesterday...
> Haha. If you look at my e-mail address, you'll notice that was me. (-;
> I didn't notice this other problem till after I posted the comment.
> Maybe you ran the P2 director application as the same user that you're
> running Eclipse as? It would probably work okay in that case.
> James
FUDForum. Page generated in 0.04714 seconds
