Looking for Corona plugin projects [message #10224] |
Mon, 10 March 2008 09:07 |
Originally posted by: canadianguy.gmail.com
Hi everyone,
I'm looking for some plugins that may have been migrated over from the
Corona project. Corona used to have a few SOA plugins used by Apache Muse.
They were designed to override the Axis2 servlet and replace the Axis
Configurator with a mechanism to make it simple for deployment of web
services from OSGi Bundles. These plugins have now disappeard from CVS
after Corona's migration to Subversive.
When I posed about this on the Corona newsgroup I got the following reply:
"Corona's source repository was moved from CVS to SVN. Only the active
projects being used by Corona's server-side platform were migrated. At this
time the SOA plugin was deprecated and not migrated to SVN.
Corona's project plan is being revised to adopt COSMOS. This Eclipse
project contains libraries for web service enablement (via WSDM). You
should check with COSMOS to determine if they have the SOA libraries you are
looking for."
Is anyone able to help me? Obviously, I would prefer to build my projects
with plugins that are actually being developed and maintained.
If you know of projects that have continued or replaced the work handled by
the org.eclipse.corona.soa.common.axis2,
org.eclipse.corona.soa.provider.axis2, and
org.eclipse.corona.soa.provider.axis2.util bundles, I would appreciate any
information you can provide.
I can provide more details about what I am trying to do and the code I was
using if necessary.
-James
FUDForum. Page generated in 0.07792 seconds
