Home » Archived » BIRT » Problems W/HTML after upgrade to RC2
Problems W/HTML after upgrade to RC2 [message #112040] Fri, 20 January 2006 00:26 Go to next message
Originally posted by: robhedin.hotmail.com
I've just upgraded to BIRT 2.0-RC2. The eclipse integration is fine,
however the Runtime deployment is giving me fits. when the call is made to
/frameset?... with the correct parameters (working with RC1), the HTML
page that comes up does not show the report output.
The 4 "buttons" at the top, the PDF button brings up the correct report in
PDF form, but none of the other 3 buttons seem to do anything.
The WAR file has
1. the 1.4.0 version of prototype.js in ajax/lib/
2. the WEB-INF/lib/ has axis/axis-ant/saaj/jaxrpc/wsdl4j/commons-discovery
3. itext is in the correct location (since the PDF comes up).
I must be missing something, but can't see it. Any clues?
rob.
Re: Problems W/HTML after upgrade to RC2 [message #112078 is a reply to message #112040] Fri, 20 January 2006 04:27 Go to previous messageGo to next message
Originally posted by: andy.lawton.nospam.com
Are you using Firefox as your browser?
Use the View Source option and you will see loads of code there - but no
report.
If you hit the print button, then the PDF report should work.
Try IE and you should get a report.
Seems to be a bug.
Andy
"Rob Hedin" <robhedin@hotmail.com> wrote in message
news:1dad0ad9792f510442211f19a6c0714a$1@www.eclipse.org...
> The WAR file has 1. the 1.4.0 version of prototype.js in ajax/lib/
> rob.
Re: Problems W/HTML after upgrade to RC2 [message #112234 is a reply to message #112078] Fri, 20 January 2006 09:15 Go to previous messageGo to next message
Yes I am using Firefox 1.5 as the browser. Didn't even think to try IE,
but that does work. Appears to be bug 124621;
Thanks!
rob.
Re: Problems W/HTML after upgrade to RC2 [message #112690 is a reply to message #112234] Fri, 20 January 2006 16:52 Go to previous message
use 1.0. 1.5 will be supported soon.
Previous Topic:BIRT installation withour Eclipse !!
Next Topic:drill-through link default servlet
Current Time: Sun Aug 31 13:33:40 EDT 2025
Powered by FUDForum. Page generated in 0.03028 seconds
