Home » Eclipse Projects » Eclipse Platform » Re: CVS Update Problem
Re: CVS Update Problem [message #112025] Mon, 18 August 2003 16:12 Go to next message
Originally posted by: Michael_Valenta.oti.com
Ralf,
The only time I've seen anything like this is when the directory in
question was being used as a build output directory. The only other
thing I can suggest is to make sure you do a refresh local before
running Team>Update if you have used an external tool on the project.
Michael
Ralf Folkerts wrote:
> I recently started using Eclipse 2.11 (used NetBeans before). I use to
> access a Project under CVS-Control.
> Now, everything works fine -- except CVS-Updates.
> When trying to Update the Project using Team - Update I get an error:
> "Problem writing Resource'project/ab/cd/ef'. Resource 'project/ab/cd/ef'
> already exists"
> That file is meant to be there, as it was checked out from CVS. The file
> reallay exists in ~/workspace/project/ab/cd and it's writable. It's also
> correctly listed in ~/workspace/project/ab/cd/CVS/Entries.
> I also tried to "cvs -d :pserver:.... update ab". That, however, runs
> thru 1a. Also I can get a proper CVS "status" on that file.
> Unfortunately, even after manually updating my project using
> command-line cvs, (Eclipsed did not run at that time) I cannot get thru
> the Eclipse Team-Update. It always reports the abovementioned error.
> That happens on two machines, one running Windows, the other Linux - but
> on different Files. On the Win-Machine I got rid of that message after
> playing around, but was unable to on Linux.
> I checked the CVS-Settings over and over again, but they seem OK :-)
> Would be great if someony had a hint!
> MTIA
> _ralf_
Re: CVS Update Problem [message #112570 is a reply to message #112025] Tue, 19 August 2003 12:43 Go to previous message
Originally posted by: ralf_folkerts.gmx.de
Michael Valenta wrote:
Michael,
well, in that particular case the Directory contained only three
XML-Schemas - and all three were not touched by an external Tool :-(
In some other cases you assumption was right: The Source-Directory also
was used for build-Output.
Thanks for the "refresh" Hint! I found that in the Manual, too and,
since then, make heavy use of it :-)
Thanks again!
_ralf_
> Ralf,
> Michael
>> already exists"
>> MTIA
>> _ralf_
Previous Topic:team project file
Next Topic:Help creating a welcome page.
Current Time: Sun Aug 31 13:34:16 EDT 2025
Powered by FUDForum. Page generated in 0.04414 seconds
