Home » Modeling » GMF (Graphical Modeling Framework) » Doing a simulation-like map with GMF
Doing a simulation-like map with GMF [message #112026] Wed, 14 March 2007 17:15 Go to next message
Originally posted by: roniburd.andrew.cmu.edu
Hi, I'm researching GMF as a possible tool for our project.
We have to create a simlation screen that will allow the user to place
elements and assigne a path to them. I've done the mindmap tutorial with
success and liked the results, but I was wondering if there anyone sees a
problem of creating this type of app with GMF.
My question is that the waypoint in a path that an element must follow,
should be X,Y as oppsosed to UML or other diagrams where position is not
important. Is there anything I should be aware of? Are there any fundamental
roadbloack to do this in GMF?
Thanks!
-Roni Burd
Graduate Student Candidate
Carnegie Mellon
Re: Doing a simulation-like map with GMF [message #112152 is a reply to message #112026] Thu, 15 March 2007 06:52 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
Hello!
Positions are stored in notation model but nonetheless they are
persisted and may be edited in precise way. There are three ways to
change positions:
1. Layout service arranges elements on diagram upon user request but may
be disabled.
2. Property sheet exposes coordinates but it may do it in read-only mode.
3. Editpolicies of editparts show handles that user may drag to modify
node bounds and link bendpoints; as the author of diagram editor you may
precisely specify their behaviour.
You may also store coordinates in domain model but in this case you
should handcode synchronization with notation model or patch logic to
use domain model directly instead of notation model.
> Thanks!
> -Roni Burd
> Carnegie Mellon
Re: Doing a simulation-like map with GMF [message #112253 is a reply to message #112152] Thu, 15 March 2007 16:50 Go to previous messageGo to next message
Thanks.
I will need to persist the coordinates in the domain model since the file
with coordinates may be suplied from an external program.
What classes should I look for the do this "logic patching"?
"Dmitry Stadnik" <5d5@mail.ru> wrote in message
news:etb8gj$m0l$1@utils.eclipse.org...
> Hello!
> Positions are stored in notation model but nonetheless they are persisted
> and may be edited in precise way. There are three ways to change
> positions:
> be disabled.
> You may also store coordinates in domain model but in this case you should
> handcode synchronization with notation model or patch logic to use domain
>> fundamental roadbloack to do this in GMF?
>> Thanks!
>> -Roni Burd
>> Carnegie Mellon
Re: Doing a simulation-like map with GMF [message #112385 is a reply to message #112253] Fri, 16 March 2007 07:05 Go to previous message
You should look for code like in SetBoundsCommand that modifies
LayoutConstraint of notation Node or Bendpoints of notation Edge.
I've just thought that you may try to listen to notation model changes
in editpart and update domain model accordingly. In fact editparts
already listen to changes in their models so you may trace events in
handleNotificationEvent(Notification) in editparts and see what happens
there.
Roni Burd wrote:
> Thanks.
> Thanks
>> Hello!
>> positions:
>> be disabled.
>>> Thanks!
>>> -Roni Burd
>>> Carnegie Mellon
Previous Topic:Taipan Example - Canvas Mapping between Port and Building, double click function
Next Topic:CreateRelationshipRequest and Container
Current Time: Sun Aug 31 13:27:59 EDT 2025
Powered by FUDForum. Page generated in 0.03148 seconds
