Home » Archived » Visual Editor (VE) » parse error with visual editor
parse error with visual editor [message #112012] Thu, 01 December 2005 00:57 Go to next message
Originally posted by: kumasi.korea.com
I installed JDK1.4 and added
"C:\Program Files\Java\j2re1.4.2_10\bin"
to the system envirement variable "Path".
and then I unzipped following four zipped files
1.eclipse-SDK-3.1-win32.zip
2.emf-sdo-runtime-2.1.0.zip
3.GEF-runtime-3.1.zip
4.VE-runtime-1.1.0.1.zip
after that, I saw "File>New>Visual Class" has been
generated. But the problem is
when I create a class that exteds swing with visual editor,
in the middle of the creation process it stops and
shows the message "Parse error"
I deleted the directory c:\eclipse and
went over the same procedure I mentioned above again.
But I could not see the difference.
It's ok when I create a class. It only happens when
creating a Visual class with visual editor.
Somebody help me please.
Re: parse error with visual editor [message #112100 is a reply to message #112012] Thu, 01 December 2005 10:58 Go to previous message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Please send the .log file. There is not enough info from just "Parse error".
Heesang Lee wrote:
> I installed JDK1.4 and added "C:\Program Files\Java\j2re1.4.2_10\bin" to
> 1.eclipse-SDK-3.1-win32.zip 2.emf-sdo-runtime-2.1.0.zip
> 3.GEF-runtime-3.1.zip 4.VE-runtime-1.1.0.1.zip
> after that, I saw "File>New>Visual Class" has been generated. But the
> problem is when I create a class that exteds swing with visual editor,
> in the middle of the creation process it stops and shows the message
> "Parse error"
> I deleted the directory c:\eclipse and went over the same procedure I
> mentioned above again. But I could not see the difference.
Rich Kulp
Re: parse error with visual editor [message #611420 is a reply to message #112012] Thu, 01 December 2005 10:58 Go to previous message
> "Parse error"
Rich Kulp
Previous Topic:Extending the VE - runtime problems
Next Topic:Dialog inheritance
Current Time: Sun Aug 31 13:34:01 EDT 2025
Powered by FUDForum. Page generated in 0.02938 seconds
