Home » Archived » Visual Editor (VE) » java.lang.NullPointerException duting open VE
java.lang.NullPointerException duting open VE [message #111580] Wed, 30 November 2005 03:59 Go to next message
Originally posted by: prohol.o2.pl
I create simple SWT application and after closing and openning
eclipse a have monit with "error trying to set new file into editor"
reason: "java.lang.NullPointerException". (eclipse 3.1.1 emf-2.1.0,
ve 1.1.0). Any suggestion? This is my log file.
!ENTRY org.eclipse.ve.java.core 4 0 2005-11-30 09:58:09.34
!MESSAGE Exception thrown.
!STACK 0
org.eclipse.ve.internal.swt.CompositeGraphicalEditPart.setup Control(CompositeGraphicalEditPart.java:96)
org.eclipse.ve.internal.swt.CompositeGraphicalEditPart.creat eChild(CompositeGraphicalEditPart.java:84)
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:733)
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:684)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:554)
org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:232)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:212)
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:195)
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:734)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.setRootModel(JavaVisualEditorPart.java:506)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.initializeViewers(JavaVisualEditorPart.java:987)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$12.run(JavaVisualEditorPart.java:1977)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!ENTRY org.eclipse.ui 4 4 2005-11-30 09:58:09.50
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-11-30 09:58:09.50
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
Caused by: java.lang.NullPointerException
... 18 more
Re: java.lang.NullPointerException duting open VE [message #111937 is a reply to message #111580] Wed, 30 November 2005 09:34 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
First try stepping up to the latest VE fix, 1.1.0.1. It has a lot of
fixes. The update manager should find it for you.
Next try clearing the cache if stepping up didn't fix it. To clear the
cache do:
1) Open a Ve, close it. Close all open VE's.
2) Do Project->Clean...->Clean All...
3) Wait for build to finish.
4) Open a VE. See if it now works.
Rich Kulp
Re: java.lang.NullPointerException duting open VE [message #112030 is a reply to message #111937] Thu, 01 December 2005 01:42 Go to previous messageGo to next message
thanks
I try this many times. I upgraded ve to 1.1.0.1 but it didn't work. In
red x button in toolbar is write "IWAV0181E Parsing Error - Click to try
reload". Maybe this help..
> cache do:
Re: java.lang.NullPointerException duting open VE [message #112074 is a reply to message #112030] Thu, 01 December 2005 10:55 Go to previous messageGo to next message
Does it happen on all SWT classes, or only on specific ones? If it is a
specific class, could you send it to us so that we can see what is wrong?
Also, please go to Eclipse's Help->About Eclipse SDK->Configuration
Details, and copy that to an append so that we can see your configuration.
prohol wrote:
> thanks
>> cache do:
Rich Kulp
Re: java.lang.NullPointerException duting open VE [message #112260 is a reply to message #112074] Fri, 02 December 2005 02:45 Go to previous messageGo to next message
A have this kind of problem with Table class I think. When I removed
createTable method ve worked fine.
My eclipse configuration:
*** Date: Fri Dec 02 08:40:24 CET 2005
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M20050929-0840
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
F:\java\eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
2c4_2c
-vm
F:\WINDOWS\system32\javaw.exe
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1133509132868
eclipse.vm=F:\WINDOWS\system32\javaw.exe
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
F:\java\eclipse\startup.jar
eof=eof
file.encoding=Cp1250
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=F:\java\eclipse\startup.jar
java.class.version=49.0
java.endorsed.dirs=F:\Program Files\Java\jre1.5.0_05\lib\endorsed
java.ext.dirs=F:\Program Files\Java\jre1.5.0_05\lib\ext
java.home=F:\Program Files\Java\jre1.5.0_05
java.io.tmpdir=F:\DOCUME~1\MARIUS~1.ELK\USTAWI~1\Temp\
java.library.path=F:\WINDOWS\system32;.;F:\WINDOWS\system32; F:\WINDOWS;F:\WINDOWS\system32;F:\WINDOWS;F:\WINDOWS\System3 2\Wbem;F:\Program
Files\java\jre1.5.0_05\bin;F:\usr\mysql\bin;F:\PROGRA~1\IBM\ IMNNQ;F:\Program
Files\SQLLIB\BIN;F:\Program Files\SQLLIB\FUNCTION;F:\Program
Files\SQLLIB\SAMPLES\REPL;F:\Program
Files\SQLLIB\HELP;f:\programs\bash\bin;f:\program
files\CodeBlocks\bin;f:\program files\CodeBlocks\minqw32\bin;řűý
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_05-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_05
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_05-b05
line.separator=
org.eclipse.jdt.debug.ui.scrapbookActive=false
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=J2SE-1.5
org.osgi.framework.language=pl
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth..login,j avax.security.auth.spi,javax.security.auth.x500,javax.securi ty.cert,javax.security.sasl,javax.sound.midi,javax.sound.mid i.spi,javax.sound.sampled,java
x.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.row set.serial,javax.sql.rowset.spi,javax.swing,javax.swing.bord er,javax.swing.colorchooser,javax.swing.event,javax.swing.fi lechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swin g.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,j avax.swing.table,javax.swing.text,javax.swing.text.html,java x.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tr ee,javax.swing.undo,javax.transaction,javax.transaction.xa,j avax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml.pa rsers,javax.xml.transform,javax.xml.transform.dom,javax.xml. transform.sax,javax.xml.transform.stream,javax.xml.validatio n,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_ 2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,o rg.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA .TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingC ontextExtPackage,org.omg.CosNaming.NamingContextPackage,org. omg.Dynamic,org.omg.DynamicAny
,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny. DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,or g.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInt erceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org. omg.PortableServer,org.omg.PortableServer.CurrentPackage,org .omg.PortableServer.POAManagerPackage,org.omg.PortableServer .POAPackage,org.omg.PortableServer.portable,org.omg.Portable Server.ServantLocatorPackage,org.omg.SendingContext,org.omg. stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom. events,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sa x.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundlestore=f:\java\eclipse\configuration\org.eclipse.o sgi\bundles
osgi.configuration.area=file:/f:/java/eclipse/configuration/
osgi.framework=file:/f:/java/eclipse/plugins/org.eclipse.osg i_3.1.1.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.1.1
osgi.install.area=file:/f:/java/eclipse/
osgi.instance.area=file:/F:/java/workspace/
osgi.instance.area.default=file:/F:/Documents and
Settings/mariusz.moleda.ELKO-SA/workspace/
osgi.logfile=F:\java\workspace\.metadata\.log
osgi.manifest.cache=f:\java\eclipse\configuration\org.eclips e.osgi\manifests
osgi.nl=pl_PL
osgi.os=win32
osgi.splashLocation=f:\java\eclipse\plugins\org.eclipse.plat form_3.1.1\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=f:\java\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=F:\Program
Files\Java\jre1.5.0_05\lib\rt.jar;F:\Program
Files\Java\jre1.5.0_05\lib\i18n.jar;F:\Program
Files\Java\jre1.5.0_05\lib\sunrsasign.jar;F:\Program
Files\Java\jre1.5.0_05\lib\jsse.jar;F:\Program
Files\Java\jre1.5.0_05\lib\jce.jar;F:\Program
Files\Java\jre1.5.0_05\lib\charsets.jar;F:\Program
Files\Java\jre1.5.0_05\classes
sun.boot.library.path=F:\Program Files\Java\jre1.5.0_05\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1250
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Dodatek Service Pack 2
user.country=PL
user.dir=F:\java\eclipse
user.home=F:\Documents and Settings\mariusz.moleda.ELKO-SA
user.language=pl
user.name=mariusz.moleda
user.timezone=Europe/Belgrade
user.variant=
*** Features:
org.eclipse.emf (2.1.1) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.doc (2.1.1) "Eclipse Modeling Framework (EMF)
Programmers Guide"
org.eclipse.emf.ecore.sdo (2.1.1) "EMF Service Data Objects (SDO)"
org.eclipse.emf.ecore.sdo.doc (2.1.1) "EMF Service Data Objects (SDO)
Programmers Guide"
org.eclipse.emf.ecore.sdo.source (2.1.1) "EMF Service Data Objects (SDO)
Source"
org.eclipse.emf.source (2.1.1) "Eclipse Modeling Framework (EMF) Source"
org.eclipse.gef (3.1.1) "Graphical Editing Framework"
org.eclipse.jdt (3.1.1) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.1.1) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.1.0.1) "Java EMF Model"
org.eclipse.pde (3.1.1) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.1.1) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.1.1) "Eclipse Platform"
org.eclipse.platform.source (3.1.1) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.rcp (3.1.1) "Eclipse RCP"
org.eclipse.rcp.source (3.1.1) "Eclipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.1.1) "Eclipse Project SDK"
org.eclipse.ve (1.1.0.1) "Visual Editor"
org.eclipse.xsd (2.1.1) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.1.1) "XML Schema Infoset Model (XSD) Programmers
Guide"
org.eclipse.xsd.source (2.1.1) "XML Schema Infoset Model (XSD) Source"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.1) "Event Model" [Active]
com.quantum.dbunit (3.0.0) "QuantumDB DbUnit Plug-in" [Resolved]
com.quantum.flatfiles (3.0.0) "QuantumDB Data Export-Import Plug-in"
[Resolved]
com.quantum.help (3.0.0) "Help Plug-in" [Resolved]
com.quantum.Quantum (3.0.0) "Quantum DB Utility" [Resolved]
net.sf.fjep.fatjar (0.0.21) "Fat Jar Plug-in" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.lucene (1.4.3) "Apache Lucene" [Resolved]
org.eclipse.ant.core (3.1.1) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.1.1) "Ant UI" [Resolved]
org.eclipse.compare (3.1.1) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.0) "Core Boot" [Resolved]
org.eclipse.core.commands (3.1.0) "Commands" [Active]
org.eclipse.core.expressions (3.1.0) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.1.0) "File Buffers" [Active]
org.eclipse.core.resources (3.1.0) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.1.0) "Core Resource
Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.1.0) "Core Resource Management Win32
org.eclipse.core.runtime (3.1.1) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.0) "Core Runtime Plug-in
Compatibility" [Active]
org.eclipse.core.variables (3.1.0) "Core Variables" [Active]
org.eclipse.debug.core (3.1.0) "Debug Core" [Active]
org.eclipse.debug.ui (3.1.1) "Debug UI" [Active]
org.eclipse.draw2d (3.1.1) "Draw2d" [Active]
org.eclipse.emf (2.1.1) "Eclipse Modeling Framework (EMF)" [Resolved]
org.eclipse.emf.ant (2.1.0) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.1.0) "EMF Template Code Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.1.0) "EMF Ecore Code Generation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.1.0) "EMF Ecore Code Generation UI"
[Resolved]
org.eclipse.emf.codegen.ui (2.1.0) "EMF Template Code Generator UI"
[Resolved]
org.eclipse.emf.common (2.1.0) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.1.0) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0) "CommonJ SDO" [Resolved]
Programmers Guide" [Resolved]
org.eclipse.emf.ecore (2.1.0) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.1.0) "EMF Ecore Change Model" [Active]
org.eclipse.emf.ecore.change.edit (2.1.0) "EMF Ecore Change Edit
Support" [Resolved]
org.eclipse.emf.ecore.edit (2.1.1) "EMF Ecore Edit Support" [Resolved]
org.eclipse.emf.ecore.editor (2.1.0) "Sample Ecore Editor" [Resolved]
[Resolved]
org.eclipse.emf.ecore.sdo.edit (2.1.0) "EMF Service Data Objects (SDO)
org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects (SDO)
Editor" [Resolved]
Source" [Resolved]
org.eclipse.emf.ecore.xmi (2.1.0) "EMF XMI" [Active]
org.eclipse.emf.edit (2.1.1) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.1.0) "EMF Edit UI" [Resolved]
org.eclipse.emf.importer (2.1.0) "EMF Model Import Support" [Resolved]
org.eclipse.emf.importer.ecore (2.1.0) "EMF Ecore Importer" [Resolved]
org.eclipse.emf.importer.java (2.1.1) "EMF Annotated Java Importer"
[Resolved]
org.eclipse.emf.importer.rose (2.1.1) "EMF Rose Importer" [Resolved]
org.eclipse.emf.mapping (2.1.0) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.1.0) "Ecore to Ecore Mapping"
[Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.1.0) "Ecore to Ecore
Mapping Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.1.0) "Ecore to XML Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.1.1) "Ecore to XML Mapping UI"
[Resolved]
org.eclipse.emf.mapping.ui (2.1.0) "EMF Mapping UI" [Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0) "XSD to Ecore Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0) "XSD to Ecore Mapping
Editor" [Resolved]
[Resolved]
org.eclipse.gef (3.1.1) "Graphical Editing Framework" [Active]
org.eclipse.help (3.1.0) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.0) "Help Application Server" [Resolved]
org.eclipse.help.base (3.1.0) "Help System Base" [Resolved]
org.eclipse.help.ui (3.1.1) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.1.0) "Help System Webapp" [Resolved]
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.core (3.1.1) "Java Development Tools Core" [Active]
org.eclipse.jdt.debug (3.1.1) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.1.1) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.1.1) "Eclipse JDT Plug-in Developer Guide"
[Resolved]
org.eclipse.jdt.doc.user (3.1.1) "Eclipse Java Development User Guide"
[Resolved]
org.eclipse.jdt.junit (3.1.1) "Java Development Tools JUnit support"
[Resolved]
org.eclipse.jdt.junit.runtime (3.1.0) "Java Development Tools JUnit
runtime support" [Resolved]
org.eclipse.jdt.launching (3.1.0) "Java Development Tools Launching
Support" [Active]
[Resolved]
org.eclipse.jdt.ui (3.1.1) "Java Development Tools UI" [Active]
org.eclipse.jem (1.1.0.1) "Java EMF Model" [Active]
org.eclipse.jem.beaninfo (1.1.0.1) "Java EMF Model BeanInfo
(Introspection) Support" [Active]
org.eclipse.jem.proxy (1.1.0.1) "Java EMF Model Proxy Support" [Active]
org.eclipse.jem.ui (1.1.0.1) "Java EMF Model UI" [Resolved]
org.eclipse.jem.util (1.1.0.1) "Java EMF Model Utilities" [Active]
org.eclipse.jem.workbench (1.1.0.1) "Java EMF Model Workbench Support"
[Active]
org.eclipse.jface (3.1.1) "JFace" [Active]
org.eclipse.jface.text (3.1.1) "JFace Text" [Active]
org.eclipse.ltk.core.refactoring (3.1.0) "Refactoring Core" [Active]
org.eclipse.ltk.ui.refactoring (3.1.1) "Refactoring UI" [Active]
org.eclipse.osgi.services (3.1.1) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.1.1) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment" [Resolved]
org.eclipse.pde.build (3.1.0) "Plug-in Development Environment Build
Support" [Resolved]
org.eclipse.pde.core (3.1.1) "Plug-in Development Core" [Active]
org.eclipse.pde.doc.user (3.1.1) "Eclipse Plug-in Development User
Guide" [Resolved]
org.eclipse.pde.junit.runtime (3.1.0) "PDE JUnit Plug-in Test" [Resolved]
org.eclipse.pde.runtime (3.1.1) "Plug-in Development Environment
Runtime" [Resolved]
Developer Resources" [Resolved]
org.eclipse.pde.ui (3.1.1) "Plug-in Development UI" [Resolved]
org.eclipse.platform (3.1.1) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.1.1) "Eclipse Platform Plug-in Developer
Guide" [Resolved]
org.eclipse.platform.doc.user (3.1.1) "Eclipse Workbench User Guide"
[Resolved]
org.eclipse.platform.source.win32.win32.x86 (3.1.1) "Eclipse Platform
Plug-in Developer Resources" [Resolved]
org.eclipse.rcp (3.1.0) "Eclipse RCP" [Resolved]
[Resolved]
org.eclipse.rcp.source.win32.win32.x86 (3.1.1) "Eclipse RCP Plug-in
org.eclipse.sdk (3.1.1) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.1.1) "Search Support" [Resolved]
org.eclipse.swt (3.1.0) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.1.1) "Standard Widget Toolkit for
Windows" [Resolved]
org.eclipse.team.core (3.1.1) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.1.1) "CVS Team Provider Core" [Resolved]
org.eclipse.team.cvs.ssh (3.1.0) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.1.0) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.1.1) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.1.1) "Team Support UI" [Resolved]
org.eclipse.text (3.1.1) "Text" [Active]
org.eclipse.tomcat (4.1.30.1) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.1.1) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.1.1) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.1.1) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.0) "Console" [Active]
org.eclipse.ui.editors (3.1.1) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.1) "External Tools" [Active]
org.eclipse.ui.forms (3.1.0) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.1.1) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.1.1) "Welcome Framework" [Resolved]
org.eclipse.ui.presentations.r21 (3.1.0) "R21 Presentation Plug-in"
[Resolved]
org.eclipse.ui.views (3.1.1) "Views" [Active]
org.eclipse.ui.win32 (3.1.0) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.1.1) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.1.0) "Workbench Compatibility"
[Resolved]
org.eclipse.ui.workbench.texteditor (3.1.1) "Text Editor Framework" [Active]
org.eclipse.update.configurator (3.1.0) "Install/Update Configurator"
[Active]
org.eclipse.update.core (3.1.1) "Install/Update Core" [Resolved]
org.eclipse.update.core.win32 (3.1.0) "Install/Update Core for Windows"
[Resolved]
org.eclipse.update.scheduler (3.1.0) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.1.1) "Install/Update UI" [Resolved]
org.eclipse.ve (1.1.0) "Visual Editor" [Resolved]
org.eclipse.ve.cde (1.1.0.1) "Visual Editor Common Data Editor" [Active]
org.eclipse.ve.doc (1.1.0) "Visual Editor for Java User Guide" [Resolved]
org.eclipse.ve.java.core (1.1.0.1) "Visual Editor Java Core" [Active]
org.eclipse.ve.jfc (1.1.0.1) "Visual Editor for Java Foundation Classes"
[Active]
org.eclipse.ve.propertysheet (1.1.0.1) "Visual Editor PropertySheet"
[Active]
org.eclipse.ve.swt (1.1.0.1) "Visual Editor for Standard Widget Toolkit"
[Active]
org.eclipse.xsd (2.1.1) "XML Schema Infoset Model (XSD)" [Resolved]
Guide" [Resolved]
org.eclipse.xsd.ecore.importer (2.1.0) "XML Schema Importer for EMF"
[Resolved]
org.eclipse.xsd.edit (2.1.0) "XML Schema Edit Framework" [Resolved]
org.eclipse.xsd.editor (2.1.0) "XML Schema Editor" [Resolved]
[Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
system.bundle (3.1.1) "OSGi System Bundle" [Active]
*** User Preferences:
#Fri Dec 02 08:40:24 CET 2005
/instance/org.eclipse.ui.ide/IDE_ENCODINGS_PREFERENCE=ISO-88 59-2
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
version\="1.0" encoding\="UTF-8"?><templates/>
@org.eclipse.ui.ide=3.1.1
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 1,0 "
defaultVMConnector\="">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="0" javadocURL\="http\://java.sun.com/j2se/1.5.0/docs/api/"
name\="jre1.5.0_05" path\="F\:\\Program
Files\\Java\\jre1.5.0_05"/>\r\n</vmType>\r\n</vmSettings >\r\n
@org.eclipse.pde.core=3.1.1
/instance/org.eclipse.ve.java.core/VISUAL_CLASS_WIZARD_SELEC TED_ELEMENT_KEY=org.eclipse.ve.swt.cat-Shell-java.lang.Objec t
/project/okno/org.eclipse.core.resources/encoding/<project>=ISO-8859-2
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.code_te mplates_migrated=true
/instance/org.eclipse.jdt.debug.ui/org.eclipse.jdt.debug.ui. show_monitor_thread_info=true
/instance/org.eclipse.pde.runtime/activate=true
/instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
@org.eclipse.jdt.ui=3.1.1
/instance/org.eclipse.core.resources/version=1
@org.eclipse.core.resources=3.1.0
/instance/org.eclipse.ui/showIntro=false
/instance/org.eclipse.help.ui/browser.y=88
/instance/org.eclipse.help.ui/browser.x=88
/instance/org.eclipse.help.ui/browser.maximized=false
/instance/org.eclipse.help.ui/browser.w=1024
/instance/org.eclipse.pde.core/platform_path=f\:\\java\\ecli pse
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
@org.eclipse.ve.java.core=1.1.0.1
file_export_version=3.0
/instance/org.eclipse.ve.java.core/NOTEBOOK_PAGE=true
@org.eclipse.jdt.launching=3.1.0
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
@org.eclipse.pde.runtime=3.1.1
/instance/org.eclipse.help.ui/browser.h=768
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.ve.java.core/PALETTE_WIDTH=125
/instance/org.eclipse.ui.ide/platformState=425
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.visibilityCheck=enabled
/instance/org.eclipse.ve.java.core/PALETTE_STATE=4
@org.eclipse.ui.editors=3.1.1
/instance/com.quantum.Quantum/com.quantum.actions.BookmarkSe lectionUtil.bookmark=mysql
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=F\:\\jav a\\workspace
/instance/org.eclipse.pde.runtime/orderType=2
/instance/org.eclipse.ui.ide/quickStart=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JUNIT_HOME=f\:/java/eclipse/plugins/org.junit_3.8. 1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_LIB=F\:/Program
Files/Java/jre1.5.0_05/lib/rt.jar
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=8
@org.eclipse.jdt.core=3.1.1
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.templat es_migrated=true
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
@org.eclipse.search=3.1.1
/instance/org.eclipse.pde.runtime/orderValue=-1
/instance/org.eclipse.update.ui/ConfigurationView.showUnconf =true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRCROOT=
/instance/org.eclipse.ui.ide/tipsAndTricks=true
@org.eclipse.jdt.debug.ui=3.1.1
/instance/org.eclipse.jdt.debug.ui/org.eclipse.jdt.debug.ui. javaDebug.alertHCRFailed=false
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
/instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.Vari ableView.org.eclipse.jdt.debug.ui.show_null_entries=true
/instance/org.eclipse.pde.runtime/column4=150
/project/okno/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.cus tom_code_templates= <?xml
version\="1.0" encoding\="ISO-8859-2"?><templates/>
/instance/org.eclipse.pde.runtime/column3=150
/instance/org.eclipse.pde.runtime/column2=420
/instance/org.eclipse.search/org.eclipse.search.defaultPersp ective=org.eclipse.search.defaultPerspective.none
/instance/com.quantum.Quantum/quantum.dialogs.bookmarkwizard .path=F\:\\j2sdk1.4.2_10\\mysql-connector-java-3.1.11\\mysql -connector-java-3.1.11-bin.jar
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL =2
@org.eclipse.update.ui=3.1.1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRC=/okna/okna
@com.quantum.Quantum=3.0.0
@org.eclipse.help.ui=3.1.1
/instance/org.eclipse.jdt.ui/fontPropagated=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.ECLIPSE_HOME=f\:/java/eclipse
@org.eclipse.ui=3.1.1
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ code_templates= <?xml
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=false
*** Current Install Configuration:
Install configuration:
Last changed on 2005-12-01
file:/f:/java/eclipse/configuration/org.eclipse.update/platf orm.xml
Configured sites:
platform:/base/
Configured features:
ID: com.quantum.dbunit.feature, Version: 3.0.0
ID: org.eclipse.jdt.source, Version: 3.1.1
ID: org.eclipse.emf.ecore.sdo.source, Version: 2.1.1
ID: org.eclipse.sdk, Version: 3.1.1
ID: org.eclipse.pde.source, Version: 3.1.1
ID: org.eclipse.rcp.source, Version: 3.1.1
ID: org.eclipse.emf.ecore.sdo.doc, Version: 2.1.1
ID: com.quantum.flatfiles.feature, Version: 3.0.0
ID: org.eclipse.platform, Version: 3.1.1
ID: org.eclipse.emf.source, Version: 2.1.1
ID: org.eclipse.jdt, Version: 3.1.0
ID: org.eclipse.jem, Version: 1.1.0.1
ID: org.eclipse.gef, Version: 3.1.1
ID: com.quantum.feature, Version: 3.0.0
ID: org.eclipse.emf, Version: 2.1.1
ID: org.eclipse.platform.source, Version: 3.1.1
ID: org.eclipse.rcp, Version: 3.1.0
ID: org.eclipse.ve, Version: 1.1.0
ID: org.eclipse.emf.sdk, Version: 2.1.1
ID: org.eclipse.xsd.source, Version: 2.1.1
ID: org.eclipse.xsd.doc, Version: 2.1.1
ID: org.eclipse.pde, Version: 3.1.0
ID: org.eclipse.xsd, Version: 2.1.1
ID: org.eclipse.emf.ecore.sdo, Version: 2.1.1
ID: org.eclipse.emf.doc, Version: 2.1.1
ID: com.quantum.help.feature, Version: 3.0.0
Configured plug-ins:
file:/f:/java/eclipse/plugins/com.ibm.etools.emf.event_3.0.0 .1/
file:/f:/java/eclipse/plugins/com.quantum.dbunit_3.0.0/
file:/f:/java/eclipse/plugins/com.quantum.flatfiles_3.0.0/
file:/f:/java/eclipse/plugins/com.quantum.help_3.0.0/
file:/f:/java/eclipse/plugins/com.quantum.Quantum_3.0.0/
file:/f:/java/eclipse/plugins/net.sf.fjep.fatjar_0.0.21/
file:/f:/java/eclipse/plugins/org.apache.ant_1.6.5/
file:/f:/java/eclipse/plugins/org.apache.lucene_1.4.3/
file:/f:/java/eclipse/plugins/org.eclipse.ant.core_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.ant.ui_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.compare_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.core.boot_3.1.0.ja r
file:/f:/java/eclipse/plugins/org.eclipse.core.commands_3.1. 0.jar
file:/f:/java/eclipse/plugins/org.eclipse.core.expressions_3 .1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.core.filebuffers_3 .1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.core.resources.com patibility_3.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.core.resources.win 32_3.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.core.resources_3.1 .0.jar
file:/f:/java/eclipse/plugins/org.eclipse.core.runtime.compa tibility_3.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.core.runtime_3.1.1 .jar
file:/f:/java/eclipse/plugins/org.eclipse.core.variables_3.1 .0.jar
file:/f:/java/eclipse/plugins/org.eclipse.debug.core_3.1.0.j ar
file:/f:/java/eclipse/plugins/org.eclipse.debug.ui_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.draw2d_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.ant_2.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.codegen.ecore. ui_2.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.codegen.ecore_ 2.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.codegen.ui_2.1 .0.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.codegen_2.1.0. jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.common.ui_2.1. 0.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.commonj.sdo_2. 1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.common_2.1.0.j ar
file:/f:/java/eclipse/plugins/org.eclipse.emf.doc_2.1.1/
file:/f:/java/eclipse/plugins/org.eclipse.emf.ecore.change.e dit_2.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.ecore.change_2 .1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.ecore.editor_2 .1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.ecore.edit_2.1 .1.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.ecore.sdo.doc_ 2.1.1/
file:/f:/java/eclipse/plugins/org.eclipse.emf.ecore.sdo.edit or_2.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.ecore.sdo.edit _2.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.ecore.sdo.sour ce_2.1.1/
file:/f:/java/eclipse/plugins/org.eclipse.emf.ecore.sdo_2.1. 1.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.ecore.xmi_2.1. 0.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.ecore_2.1.0.ja r
file:/f:/java/eclipse/plugins/org.eclipse.emf.edit.ui_2.1.0. jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.edit_2.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.importer.ecore _2.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.importer.java_ 2.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.importer.rose_ 2.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.importer_2.1.0 .jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.mapping.ecore2 ecore.editor_2.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.mapping.ecore2 ecore_2.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.mapping.ecore2 xml.ui_2.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.mapping.ecore2 xml_2.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.mapping.ui_2.1 .0.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.mapping.xsd2ec ore.editor_2.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.mapping.xsd2ec ore_2.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.mapping_2.1.0. jar
file:/f:/java/eclipse/plugins/org.eclipse.emf.source_2.1.1/
file:/f:/java/eclipse/plugins/org.eclipse.emf_2.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.gef_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.help.appserver_3.1 .0.jar
file:/f:/java/eclipse/plugins/org.eclipse.help.base_3.1.0.ja r
file:/f:/java/eclipse/plugins/org.eclipse.help.ui_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.help.webapp_3.1.0/
file:/f:/java/eclipse/plugins/org.eclipse.help_3.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.jdt.core_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.jdt.debug.ui_3.1.1 .jar
file:/f:/java/eclipse/plugins/org.eclipse.jdt.debug_3.1.1/
file:/f:/java/eclipse/plugins/org.eclipse.jdt.doc.isv_3.1.1/
file:/f:/java/eclipse/plugins/org.eclipse.jdt.doc.user_3.1.1 /
file:/f:/java/eclipse/plugins/org.eclipse.jdt.junit.runtime_ 3.1.0/
file:/f:/java/eclipse/plugins/org.eclipse.jdt.junit_3.1.1/
file:/f:/java/eclipse/plugins/org.eclipse.jdt.launching_3.1. 0.jar
file:/f:/java/eclipse/plugins/org.eclipse.jdt.source_3.1.1/
file:/f:/java/eclipse/plugins/org.eclipse.jdt.ui_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.jdt_3.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.jem.beaninfo_1.1.0 .1/
file:/f:/java/eclipse/plugins/org.eclipse.jem.proxy_1.1.0.1/
file:/f:/java/eclipse/plugins/org.eclipse.jem.ui_1.1.0.1/
file:/f:/java/eclipse/plugins/org.eclipse.jem.util_1.1.0.1/
file:/f:/java/eclipse/plugins/org.eclipse.jem.workbench_1.1. 0.1/
file:/f:/java/eclipse/plugins/org.eclipse.jem_1.1.0.1/
file:/f:/java/eclipse/plugins/org.eclipse.jface.text_3.1.1.j ar
file:/f:/java/eclipse/plugins/org.eclipse.jface_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.ltk.core.refactori ng_3.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.ltk.ui.refactoring _3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.osgi.services_3.1. 1.jar
file:/f:/java/eclipse/plugins/org.eclipse.osgi.util_3.1.1.ja r
file:/f:/java/eclipse/plugins/org.eclipse.osgi_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.pde.build_3.1.0/
file:/f:/java/eclipse/plugins/org.eclipse.pde.core_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.pde.doc.user_3.1.1 /
file:/f:/java/eclipse/plugins/org.eclipse.pde.junit.runtime_ 3.1.0/
file:/f:/java/eclipse/plugins/org.eclipse.pde.runtime_3.1.1. jar
file:/f:/java/eclipse/plugins/org.eclipse.pde.source_3.1.1/
file:/f:/java/eclipse/plugins/org.eclipse.pde.ui_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.pde_3.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.platform.doc.isv_3 .1.1/
file:/f:/java/eclipse/plugins/org.eclipse.platform.doc.user_ 3.1.1/
file:/f:/java/eclipse/plugins/org.eclipse.platform.source.wi n32.win32.x86_3.1.1/
file:/f:/java/eclipse/plugins/org.eclipse.platform.source_3. 1.1/
file:/f:/java/eclipse/plugins/org.eclipse.platform_3.1.1/
file:/f:/java/eclipse/plugins/org.eclipse.rcp.source.win32.w in32.x86_3.1.1/
file:/f:/java/eclipse/plugins/org.eclipse.rcp.source_3.1.1/
file:/f:/java/eclipse/plugins/org.eclipse.rcp_3.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.sdk_3.1.1/
file:/f:/java/eclipse/plugins/org.eclipse.search_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.swt.win32.win32.x8 6_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.swt_3.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.team.core_3.1.1.ja r
file:/f:/java/eclipse/plugins/org.eclipse.team.cvs.core_3.1. 1.jar
file:/f:/java/eclipse/plugins/org.eclipse.team.cvs.ssh2_3.1. 0/
file:/f:/java/eclipse/plugins/org.eclipse.team.cvs.ssh_3.1.0 .jar
file:/f:/java/eclipse/plugins/org.eclipse.team.cvs.ui_3.1.1. jar
file:/f:/java/eclipse/plugins/org.eclipse.team.ui_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.text_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.tomcat_4.1.30.1/
file:/f:/java/eclipse/plugins/org.eclipse.ui.browser_3.1.1.j ar
file:/f:/java/eclipse/plugins/org.eclipse.ui.cheatsheets_3.1 .1.jar
file:/f:/java/eclipse/plugins/org.eclipse.ui.console_3.1.0.j ar
file:/f:/java/eclipse/plugins/org.eclipse.ui.editors_3.1.1.j ar
file:/f:/java/eclipse/plugins/org.eclipse.ui.externaltools_3 .1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.ui.forms_3.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.ui.ide_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.ui.intro_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.ui.presentations.r 21_3.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.ui.views_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.ui.win32_3.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.ui.workbench.compa tibility_3.1.0/
file:/f:/java/eclipse/plugins/org.eclipse.ui.workbench.texte ditor_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.ui.workbench_3.1.1 .jar
file:/f:/java/eclipse/plugins/org.eclipse.ui_3.1.1.jar
file:/f:/java/eclipse/plugins/org.eclipse.update.configurato r_3.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.update.core.win32_ 3.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.update.core_3.1.1. jar
file:/f:/java/eclipse/plugins/org.eclipse.update.scheduler_3 .1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.update.ui_3.1.1.ja r
file:/f:/java/eclipse/plugins/org.eclipse.ve.cde_1.1.0.1/
file:/f:/java/eclipse/plugins/org.eclipse.ve.doc_1.1.0/
file:/f:/java/eclipse/plugins/org.eclipse.ve.java.core_1.1.0 .1/
file:/f:/java/eclipse/plugins/org.eclipse.ve.jfc_1.1.0.1/
file:/f:/java/eclipse/plugins/org.eclipse.ve.propertysheet_1 .1.0.1/
file:/f:/java/eclipse/plugins/org.eclipse.ve.swt_1.1.0.1/
file:/f:/java/eclipse/plugins/org.eclipse.ve_1.1.0/
file:/f:/java/eclipse/plugins/org.eclipse.xsd.doc_2.1.1/
file:/f:/java/eclipse/plugins/org.eclipse.xsd.ecore.importer _2.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.xsd.editor_2.1.0.j ar
file:/f:/java/eclipse/plugins/org.eclipse.xsd.edit_2.1.0.jar
file:/f:/java/eclipse/plugins/org.eclipse.xsd.source_2.1.1/
file:/f:/java/eclipse/plugins/org.eclipse.xsd_2.1.1.jar
file:/f:/java/eclipse/plugins/org.junit_3.8.1/
> prohol wrote:
>> thanks
>> try reload". Maybe this help..
>>> the cache do:
Re: java.lang.NullPointerException duting open VE [message #112285 is a reply to message #112260] Fri, 02 December 2005 10:23 Go to previous message
Can you append the createTable method that causes failure?
Rich Kulp
Re: java.lang.NullPointerException duting open VE [message #611381 is a reply to message #111580] Wed, 30 November 2005 09:34 Go to previous message
cache do:
Rich Kulp
Re: java.lang.NullPointerException duting open VE [message #611409 is a reply to message #111937] Thu, 01 December 2005 01:42 Go to previous message
thanks
> cache do:
Re: java.lang.NullPointerException duting open VE [message #611417 is a reply to message #112030] Thu, 01 December 2005 10:55 Go to previous message
prohol wrote:
> thanks
>> cache do:
Rich Kulp
Re: java.lang.NullPointerException duting open VE [message #611442 is a reply to message #112074] Fri, 02 December 2005 02:45 Go to previous message
win32
-ws
win32
-arch
x86
-launcher
-name
Eclipse
-showsplash
600
-exitdata
2c4_2c
-vm
-Xmx256m
-jar
eof=eof
file.separator=\
line.separator=
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.nl=pl_PL
osgi.os=win32
osgi.ws=win32
path.separator=;
sun.cpu.isalist=
sun.desktop=windows
user.country=PL
user.language=pl
user.variant=
*** Features:
Programmers Guide"
Programmers Guide"
Source"
Resources"
Guide"
[Resolved]
[Resolved]
[Resolved]
Support" [Resolved]
[Resolved]
Editor" [Resolved]
Source" [Resolved]
[Resolved]
[Resolved]
[Resolved]
Editor" [Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
Support" [Active]
[Resolved]
[Active]
Support" [Resolved]
Guide" [Resolved]
Runtime" [Resolved]
Guide" [Resolved]
[Resolved]
[Resolved]
Windows" [Resolved]
[Resolved]
[Resolved]
[Active]
[Resolved]
[Active]
[Active]
[Active]
Guide" [Resolved]
[Resolved]
[Resolved]
Configured sites:
platform:/base/
> prohol wrote:
>> thanks
>>> the cache do:
Re: java.lang.NullPointerException duting open VE [message #611446 is a reply to message #112260] Fri, 02 December 2005 10:23 Go to previous message
Rich Kulp
Previous Topic:IllegalArgumentExceptions in VE
Next Topic:How to make styledText "visible" in other files.
Current Time: Sun Jul 27 03:09:31 EDT 2025
Powered by FUDForum. Page generated in 1.25478 seconds
