Home » Modeling » GMF (Graphical Modeling Framework) » Removal of element children not immediately visible in editor
Removal of element children not immediately visible in editor [message #111525] Tue, 13 March 2007 10:16 Go to next message
Originally posted by: newsgroups.elmarweber.org
I'm updating the children of an element when one of its references is
changed.
When I add a child to the EMF model element its visual representation is
immediately added. When I remove the child from the EMF model the visual
representation is not removed immediately. Only when I reopen the
diagram editor it is removed.
The code is in the corresponding ???CanonialEditPolicy#
handleNotificationEvent().
I traced the notification chain after I removed the model element to
CanonialEditPolicy#deleteViews() where ???CanonialEditPolicy#
* @generated
protected boolean shouldDeleteView(View view) {
return view.isSetElement() && view.getElement() != null
&& view.getElement().eIsProxy();
is called. The last part, view.getElement().eIsProxy(), evaluates to
false, which prevents the removal from the visual model.
When I remove view.getElement().eIsProxy() the code works as expected.
Is something in my EMF/GMF model out of order or is there a problem with
the generated code?
Elmar Weber
Re: Removal of element children not immediately visible in editor [message #111604 is a reply to message #111525] Tue, 13 March 2007 13:43 Go to previous messageGo to next message
Hello Elmar,
Try search existing answers to your question in this newsgroup like: http://www.eclipse.org/search/search.cgi?q=shouldDeleteView& amp;form=extended&wf=574a74&ps=10&m=all&t=5& amp;ul=&wm=wrd&t=News&t=Mail
Alex Shatalin
Re: Removal of element children not immediately visible in editor [message #111656 is a reply to message #111604] Tue, 13 March 2007 14:17 Go to previous message
Hello Alex,
thanks for the hint, I somehow missed to search for that one.
ciao,
Elmar Weber
Previous Topic:Problems with generated navigator and properties view
Next Topic:GMF with UML Profile ?
Current Time: Sun Jul 27 08:35:21 EDT 2025
Powered by FUDForum. Page generated in 0.04520 seconds
