Home » Archived » BIRT » Chart engine unable to handle charts with parameters
Chart engine unable to handle charts with parameters [message #111414] Thu, 19 January 2006 05:39 Go to next message
Originally posted by: maspeli.deloitte.co.uk
I have a query that returns three columns: A Name, a Count and a
Classification. I want to display a stacked bar chart, showing a breakdown
of Count by Classification for each name (so x-axis = Name, y-axis = Count,
y-axis grouping = Classification). The query takes a single parameter, a
TestDate.
I'm having two problems with this.
The first one is that once I assign the parameter (so map param 1 to
params["TestDate"]) Birt starts spewing exceptions at me, telling me that
params is not defined. This generally used to work fine at run time but not
at design time. However, as of 2.0RC1, when this exception starts occuring,
BIRT is no longer saving any changes to my chart. That is, I change some
settings (i.e. the parameter assignment, but also things like where the
labels are positioned and turning on gridliens), click Finish, run the
report, and BIRT is ignorant of any of my changes. When I return to the
chart, the old settings are still there. This basically renders the charting
engine useless when I need the chart query to be parameterised, because I
can't set that parameter in the first place!
Secondly, from M3 I had a chart that used to come up with the exception, but
that actually ran the report. However, there are about 17 different Names
being returned at the present time. Because the chart is not so big in the
designer, BIRT starts grouping the labels for this chart (I have flipped it
so it's horizontal rather than vertical), which makes it confusing since
each value for Name (the x-axis) is a discrete value. Is there some option
I'm missing? I tried a few, but because of the bug above, I can't be sure if
my changes actually changed anything!
Martin
Re: Chart engine unable to handle charts with parameters [message #111509 is a reply to message #111414] Thu, 19 January 2006 07:06 Go to previous messageGo to next message
not
occuring,
charting
So, here's what I currently do:
If I use a Date Parameter, I get an error saying that metaData.data and/or
data.data don't exist. So,
- I make my query take a String parameter with a default value '2006-01-01'
(which to SQL is also a date).
- Then I edit my chart, setting the options I want
- Then I go to the parameters screen in the chart and set a string value for
the parameter, '2006-01-02'
- Then I go back to the query, change it back to a DateTime parameter with
default value new Date()
- Then I edit the XML source, replacing '2006-01-01' in the parameter
definition for the chart, with param["TestDate"]
And then if I want to change anything else in the chart, I have to repeat
the entire process or change the XML only.
Hardly ideal :)
Martin
Re: Chart engine unable to handle charts with parameters [message #111581 is a reply to message #111414] Thu, 19 January 2006 07:51 Go to previous messageGo to next message
Did you try with RC2? I think we fixed the exceptions problem. You will see
the exception only once now.
What happens is that at design time, params is not defined, so we can't
evaluate it, the chart builder warns you once (we have no way currently of
identifying this particular error, we'll do that in a future release), and
then reverts to non-live data.
What do you mean by "grouping the labels"? If some labels disappear because
there is no space for all of them, there are several solutions:
- Stagger the labels
- Change the orientation of labels
David
"Martin Aspeli" <maspeli@deloitte.co.uk> wrote in message
news:dqnq8h$kdq$1@utils.eclipse.org...
> Count,
> TestDate.
> not
> occuring,
> charting
> but
> it
> if
> Martin
Re: Chart engine unable to handle charts with parameters [message #111590 is a reply to message #111509] Thu, 19 January 2006 07:52 Go to previous messageGo to next message
Please let us know quickly if RC2 didn't fix the issue.
David
news:dqnvbc$t7k$1@utils.eclipse.org...
> not
> occuring,
> charting
> '2006-01-01'
> for
> definition for the chart, with param[&quot;TestDate&quot;]
> Hardly ideal :)
> Martin
Re: Chart engine unable to handle charts with parameters [message #111613 is a reply to message #111581] Thu, 19 January 2006 09:00 Go to previous messageGo to next message
see
No, I'm about to do that now, in fact. Will let you know.
Does your fix cause the chart viewer to properly *save* chart options even
when you get an exception because of a missing params? Basically, the
behaviour I'm seeing is that if I get that exception, subsequent changes in
chart properties don't persist when I click Finish.
Why can't you just build a fake params map, that simply uses the default
values specified in the parameter collection?
because
Yeah, that's it. I got there in the end, the problem was the fact that
changes didn't persist as described above, and it was confusing me. :)
Martin
Re: Chart engine unable to handle charts with parameters [message #111641 is a reply to message #111590] Thu, 19 January 2006 09:49 Go to previous messageGo to next message
"David Michonneau" <dmichonneau@actuate.com> wrote in message
news:dqo22c$25n$1@utils.eclipse.org...
I still get the exception, but it seems I can at least change chart
properties now. :)
Martin
Re: Chart engine unable to handle charts with parameters [message #111682 is a reply to message #111641] Thu, 19 January 2006 11:52 Go to previous messageGo to next message
Hi Martin,
Yes, getting the exception once is expected. The reason is that params is
only available at run-time, thus the Rhino engine returns an error. There
are a few runtime expressions for which this happens, we will work in a
future release to identify them and show a better message in those cases.
David
news:dqo8uc$fid$1@utils.eclipse.org...
> properties now. :)
> Martin
Re: Chart engine unable to handle charts with parameters [message #111687 is a reply to message #111613] Thu, 19 January 2006 11:55 Go to previous message
What if a parameter doesn't have a default value? The issue is not limited
to parameters, it's only one of the runtime expressions that fail. Please
take a look at this bug 122864 , you can input some suggestions if you like.
David
Previous Topic:How to validate report set parameter
Next Topic:Storing DB password outside .rptdesign file
Current Time: Thu Jul 17 22:25:44 EDT 2025
Powered by FUDForum. Page generated in 0.33501 seconds
