Home » Archived » Test and Performance Tools Platform (TPTP) » Attaching to remote JVM to profile it from workbench fails
Attaching to remote JVM to profile it from workbench fails [message #111150] |
Mon, 03 September 2007 07:47  |
Originally posted by: hichamm.orcsoftware.com
Server Linux Opteron, using
agntctrl.linux_em64t-TPTP-4.4.1-200708280100.zip
1.TPTP_AC_HOME=/tmp/hichamm/
PATH contains /tmp/hichamm/bin
LD_LIBRARY_PATH contains
/tmp/hichamm/lib/:/tmp/hichamm/plugins/org.eclipse.tptp.java profiler/
JAVA_PROFILER_HOME=/tmp/hichamm/plugins/org.eclipse.tptp.jav aprofiler
2. I start ACStart.sh and run successfully SampleClient
3. I start an inhouse process, that loads the JVM1.6.0 .so for linux
x86-64,
with these jvm optioms:
-verbose
-agentlib:jdwp=transport=dt_socket,address=8456,server=y,sus pend=n
-agentlib:JPIBootLoader=JPIAgent:server=enabled;CGProf:execd etails=true
4. from my WinXP32 eclipse europa 3.3.0 (june25 build), I go to Profiling
perspective: set serverhost, the port, test connection ok, in Agents, i
select the execution time analysis.
I click Profile, then eclipse shows Launching processname, connection to
JVMTI agent, and then
the process (with shared-in jvm) exits.
The only error the JVM reports to stdout/err is
[Error: Attach failed]
servicelog.log shows:
<CommonBaseEvent creationTime="2007-09-03T11:43:04.041278Z"
globalInstanceId="A6DBF3480000A1355A5C3D9B7501A70A" msg="Agent is locked"
severity="50" version="1.0.1">
<sourceComponentId component="AgentController"
componentIdType="TPTPComponent" executionEnvironment="AgentManager.c, line
3659" instanceId="1" location="k2.orcsoftware.com" locationType="IPV4"
processId="15953" subComponent="Agent Manager" threadId="15953"
componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2007-09-03T11:43:04.791237Z"
globalInstanceId="A6DBF348000C12BE7BB36F3A66FE5ED1" msg="Agent is locked"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2007-09-03T11:43:40.650510Z"
globalInstanceId="A6DBF36C0009ED0661B22C8F449B1D26" msg="Agent is locked"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2007-09-03T11:43:42.791749Z"
globalInstanceId="A6DBF36E000C14BD58084EB33666979F" msg="The requested
connection (119d) could not be found during sendMessage" severity="50"
version="1.0.1">
componentIdType="TPTPComponent" executionEnvironment="ConnectionManager.c,
line 534" instanceId="2" location="k2.orcsoftware.com" locationType="IPV4"
processId="15953" subComponent="Connection Manager" threadId="15953"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2007-09-03T11:43:42.792243Z"
globalInstanceId="A6DBF36E000C16AE3598E63B635F790B" msg="A
processExitedEvent was received for which we have no corresponding agent."
severity="30" version="1.0.1">
3006" instanceId="1" location="k2.orcsoftware.com" locationType="IPV4"
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2007-09-03T11:43:42.792657Z"
globalInstanceId="A6DBF36E000C184D7E48542A6BBF2DDD" msg="A
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2007-09-03T11:43:42.793092Z"
globalInstanceId="A6DBF36E000C1A011A8EC7BB3697E3ED" msg="A
<situationType
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2007-09-03T11:43:42.793492Z"
globalInstanceId="A6DBF36E000C1B9132EA578933C23D71" msg="A
<situationType
</situation>
</CommonBaseEvent>
a few errors appear there,
best regards,
Re: Attaching to remote JVM to profile it from workbench fails [message #112945 is a reply to message #112223] |
Thu, 20 September 2007 10:44   |
Hicham wrote:
> Your suspicion was correct.
> Removing the debugger from the JVM let the eclipse attach correctly to
> the JVM.
> I managed to monitor the JVM from eclipse, my filter was properly defined,
> and i didn't get any info into the workbench alors.
> It said in the bottom "Time elapsed" 200seconds
> One thing though, on the server box,.../config/servicelog.log, instead
> of containing text lines, contained binary data. Is it possible the
> profiling output from the agent went to servicelog.log instead of the
> eclipse workbench?
> I then set the MARTINI env variables. The result is here:
> All entries in the M*log file are 'informative'.
> servicelog.log is also bin data. (40kb)
> in eclipse, Execution Time ANalysis are all empty.
> Your help is appreciated,
I am sorry, but I was under the impression that your problem was
resolved. Can you please describe the problem in more details?
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Re: Attaching to remote JVM to profile it from workbench fails [message #113023 is a reply to message #112945] |
Fri, 21 September 2007 04:33   |
Hello
I managed to connect eclipse to the remote JVM, my filter was properly
defined,
but i didn't get any info into the workbench. In the bottom, it says "Time
elapsed 200seconds"
One thing though, on the server box,../config/servicelog.log, instead of
containing text lines as usual, contained binary data. Is it possible the
eclipse workbench?
I then set the MARTINI env variables. All entries in the M*log file are
'informative' entries. No errros.
in eclipse, Execution Time Analysis window is all empty.
rds,
Current Time: Fri Jul 18 23:06:18 EDT 2025
Powered by FUDForum. Page generated in 0.05429 seconds
