Home » Language IDEs » ServerTools (WTP) » Error in Project Explorer
Error in Project Explorer [message #111040] Mon, 13 June 2005 20:48 Go to next message
When I click the right mouse button in the J2EE Project Explorer on any Item
I get following Eclipse Error: "An error has occurred. See error log for
more details." No context menu shows up.
The Error log says this:
!ENTRY org.eclipse.jface 4 2 2005-06-14 00:34:58.521
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
java.lang.NoSuchMethodError:
org.eclipse.jdt.internal.ui.actions.ActionMessages.getString (Ljava/lang/String;)Ljava/lang/String;
org.eclipse.jst.common.navigator.internal.actions.OpenAction . <init>(OpenAction.java:78)
org.eclipse.jst.common.navigator.internal.actions.OpenEditor ActionGroup. <init>(OpenEditorActionGroup.java:66)
org.eclipse.jst.common.navigator.internal.actions.NavigateAc tionGroup. <init>(NavigateActionGroup.java:52)
org.eclipse.jst.common.navigator.internal.actions.OpenAction sExtension.init(OpenActionsExtension.java:72)
org.eclipse.wst.common.navigator.internal.provisional.views. NavigatorActionService.initialize(NavigatorActionService.jav a:379)
org.eclipse.wst.common.navigator.internal.provisional.views. NavigatorActionService.getActionProviderInstance(NavigatorAc tionService.java:280)
org.eclipse.wst.common.navigator.internal.provisional.views. NavigatorActionService.fillActionBars(NavigatorActionService .java:229)
org.eclipse.wst.common.navigator.internal.provisional.views. CommonNavigatorManager.selectionChanged(CommonNavigatorManag er.java:97)
        at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:162)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1038)
        at org.eclipse.core.runtime.Platform.run(Platform.java:775)
!ENTRY org.eclipse.ui 4 4 2005-06-14 00:34:58.565
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-06-14 00:34:58.566
!MESSAGE
!STACK 0
org.eclipse.wst.common.navigator.internal.provisional.views. NavigatorActionService.addCommonActionProviderMenu(Navigator ActionService.java:163)
org.eclipse.wst.common.navigator.internal.provisional.views. NavigatorActionService.fillContextMenu(NavigatorActionServic e.java:147)
org.eclipse.wst.common.navigator.internal.provisional.views. CommonNavigatorManager.fillContextMenu(CommonNavigatorManage r.java:127)
org.eclipse.wst.common.navigator.internal.provisional.views. CommonNavigatorManager$1.menuAboutToShow(CommonNavigatorMana ger.java:144)
org.eclipse.jface.action.MenuManager.fireAboutToShow(MenuMan ager.java:285)
org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuM anager.java:372)
I'm using Eclipse 3.1m7 on Gentoo Linux with the actual WebTool 1.0M4.
Any Hints?
Martin
(Sorry for the long lines...)
Re: Error in Project Explorer [message #111088 is a reply to message #111040] Mon, 13 June 2005 21:14 Go to previous message
> !STACK 0
> Any Hints?
> Martin
WTP M4 was built for Eclipse 3.1m6, and you're seeing the fallout of
using a different version. I'd suggest looking at a more recent
Integration build if you wish to use Eclipse 3.1M7, or even one of
the Eclipse RC builds.
- Nitin
Previous Topic:Error in runtime; workspace cannot be set. Exiting.
Next Topic:AXIS engine could not find a target service
Current Time: Tue Jul 15 12:35:45 EDT 2025
Powered by FUDForum. Page generated in 0.29576 seconds
