| CanonicalConnectionEditPolicy [message #841] |
Fri, 28 July 2006 15:58  |
Originally posted by: vcciubot.uwaterloo.ca
Hi all,
Following the logic example, I'm installing a
CanonicalConnectionEditPolicy on a CompartmentEditPart. The semantic
element corresponding to the compartment can have connections.
When I create connections using a connection tool, the underlying
semantic element get created, the view gets created but the
ConnectionEditPart does not.
The method getSemanticConnectionsList() of
CanonicalConnectionEditPolicy does not get called. For some reason
the CanonicalConnectionEditPolicy is being disabled via a
ToggleCanonicalModeCommand command.
thanks for your help!
vlad
| Re: CanonicalConnectionEditPolicy [message #871 is a reply to message #841] |
Fri, 28 July 2006 16:29  |
Problem fixed. The view wasn't getting create either.
On Fri, 28 Jul 2006 15:58:34 -0400, Vlad Ciubotariu wrote:
> Hi all,
> vlad
FUDForum. Page generated in 0.04234 seconds
