Home » Newcomers » Newcomers » Can´t use CTRL+F11 shortcut
Can´t use CTRL+F11 shortcut [message #110912] Sun, 23 October 2005 05:32 Go to next message
I found out this is the best options to run my program.
But when I press it (focus is in the editor) nothing happens. If I click the
command in the menu everything works.
What could be wrong here?
regards
Michael
Re: Can´t use CTRL+F11 shortcut [message #111211 is a reply to message #110912] Mon, 24 October 2005 14:50 Go to previous messageGo to next message
Are you using Linux? Could it be that your window manager is already
using this keybinding?
-Billy
Re: Can´t use CTRL+F11 shortcut [message #111334 is a reply to message #111211] Mon, 24 October 2005 18:06 Go to previous message
>> the command in the menu everything works.
> -Billy
Yes you were right, that was assigned by KDE.
Thanks for your help :)
Previous Topic:javadoc
Next Topic:Problem with 3.1.1 update
Current Time: Mon Jul 21 21:51:44 EDT 2025
Powered by FUDForum. Page generated in 0.34474 seconds
