Eclipse 3.1RC2 and wtp-I20050610 [message #110892] |
Mon, 13 June 2005 05:33  |
Originally posted by: dombat.ixemel.net
Using wtp integration wtp-I20050610 (and the associated librairies) with
eclipse 3.1RC2, when I try to edit a wsdl file. I get :
An error has occurred when initializing the input for the the editor's
source page.
org.eclipse.wst.wsdl.ui.internal.WSDLEditor.createPages(WSDL Editor.java:198)
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:241)
And trying to edit an xml file (web.xml), I get :
java.lang.NoClassDefFoundError:
org/eclipse/wst/xml/uriresolver/util/IdResolver
org.eclipse.wst.xml.core.internal.modelhandler.XMLModelLoade r.getAdapterFactories(XMLModelLoader.java:52)
Did I miss something?
Dom
Re: Eclipse 3.1RC2 and wtp-I20050610 [message #110965 is a reply to message #110956] |
Mon, 13 June 2005 13:45   |
Michal a écrit :
> yes, you missed reading info about which version of Eclipse SDK was used
> to build and test that integration build. As you can see on download
> page, "The Eclipse driver used in this build is
> eclipse-SDK-3.1RC1-linux-gtk.tar.gz". API in RCx shouldn't change, but
> you still should be aware of some incompatibility issues.
> Michal
Thanks Michal, but back home, I've just installed them as at work, and
every thing is ok, the wsdl and xml editors work perfectly
For those interested, with this config, the "J2EE Web project" is back,
and the Export "war file" too!!! No more f... "Flexible java project" !
Re: Eclipse 3.1RC2 and wtp-I20050610 [message #110977 is a reply to message #110965] |
Mon, 13 June 2005 15:37   |
Originally posted by: bob.objfac.com
Does this mean wtp-I20050610 works in RC2 or you installed them in RC1?
Thanks.
Bob
Dom wrote:
>> used to build and test that integration build. As you can see on
>> download page, "The Eclipse driver used in this build is
>> Michal
Re: Eclipse 3.1RC2 and wtp-I20050610 [message #110988 is a reply to message #110977] |
Mon, 13 June 2005 16:44   |
> Thanks.
> Bob
>>> but you still should be aware of some incompatibility issues.
>>> Michal
>> back, and the Export "war file" too!!! No more f... "Flexible java
>> project" !
Installed in RC2, as quoted in my subject
The only difference is that my editor problem at work is under xp,
whereas at home it's under 2000 pro
Dom
Re: Eclipse 3.1RC2 and wtp-I20050610 [message #111014 is a reply to message #110988] |
Mon, 13 June 2005 17:28  |
Ah, works on WinXP, maybe not other platforms. Thanks.
Bob
>> RC1? Thanks.
>> Bob
>>>> Michal
>>> and every thing is ok, the wsdl and xml editors work perfectly
>>> project" !
> Dom
FUDForum. Page generated in 0.04304 seconds
