Re: Ctrl+Space for Code Assistant and Template code generation not working [message #12373 is a reply to message #11492] |
Fri, 02 May 2003 12:24  |
Originally posted by: Kevin.clark.accessbc.com.nospam
Dale, in your case the content assist isn't working because of the errors
in your files. If the content assist cannot find a logical path through
your code, it can't suggest any completions. For example, if you have
accidentally misprinted an import statement, content assist will not be
able to see any classes or methods from the mispelt package.
I believe Anil was describing the problem where content assist never
works. Which I am certain is because of X-Men XML or another plug-in that
declares CTRL+Space as a key accelerator.
Anyways, I hope this helps to clarify your content assist probs. :)
Kevin
Dale King wrote:
> "Anil Patel" <anilpatel@mailcity.com> wrote in message
> news:b8pmbs$tp5$1@rogue.oti.com...
> > I upgrated to Eclipse 2.1. Since moving to version
> > Ctrl+Space to enable content assist Is not working.
> > Can some body help in fixing this.
> It works in general for me, but occasionally I find that it doesn't work for
> me. I know that sometimes it can get screwed up if there are too many errors
> in the source file, but when I see it the only error is the incomplete name
> I am trying to complete. I haven't found a reproducible test case. Wondering
> if anyone else has seen that.
> And FYI, the only plug-ins I have added are checkstyle and Jalopy.
> Dale King
FUDForum. Page generated in 0.03951 seconds
