Home » Newcomers » Newcomers » Compiling without running
Compiling without running [message #110834] Sat, 22 October 2005 15:23 Go to next message
Can I just compile my java project without running it (to test it for
errors). I haven´t found any option for doing this :(
regards
Michael
Re: Compiling without running [message #110846 is a reply to message #110834] Sat, 22 October 2005 17:21 Go to previous messageGo to next message
Originally posted by: wegener.cboenospam.com
Michael Stather wrote:
> regards
> Michael
If you have AutoBuild turned on, the project is built everytime you save
a file.
Re: Compiling without running [message #110857 is a reply to message #110846] Sat, 22 October 2005 18:01 Go to previous messageGo to next message
>> regards
>> Michael
> a file.
Where can I turn that feature off? And can I compile manually?
Tanks in advance for your help :)
Re: Compiling without running [message #110868 is a reply to message #110857] Sat, 22 October 2005 19:33 Go to previous messageGo to next message
You can disable auto builds by unchecking Build Automatically from the
Project menu. After that, you can build your project via the Project
menu. However, disabling the automatic builds will disable a
significant portion of Eclipse's Java tools functionality - do you have
a particular reason why you want to build manually? The normal way to
use Eclipse is to rely on its builds unless you have a special build
process requiring Ant or other processing steps.
- Jeff
Re: Compiling without running [message #110880 is a reply to message #110868] Sat, 22 October 2005 20:07 Go to previous messageGo to next message
> - Jeff
OK I just understood the benefits of save->compile.
Re: Compiling without running [message #110901 is a reply to message #110880] Sun, 23 October 2005 02:52 Go to previous messageGo to next message
>> - Jeff
> Thanks
I always turn off the "Build Automatically" option, for sometimes that's
too boring to wait for the compile process even if it just took 1
second. Why not just make Ant handle the whole building process?
Re: Compiling without running [message #111461 is a reply to message #110901] Tue, 25 October 2005 08:20 Go to previous messageGo to next message
"too boring" to wait 1 s?
Oh god.
And how does Ant make it quicker?
Re: Compiling without running [message #111537 is a reply to message #110901] Tue, 25 October 2005 09:49 Go to previous message
Are you using a network drive?
Use a local drive. It makes a BIG difference.
Previous Topic:Compiling...
Next Topic:JFACE - src
Current Time: Mon Jul 21 23:51:45 EDT 2025
Powered by FUDForum. Page generated in 0.34012 seconds
