Home » Language IDEs » C / C++ IDE (CDT) » can't use custom build
can't use custom build [message #110832] Thu, 15 July 2004 08:44 Go to next message
To minimize the load on our desktop machines, all our compiles are done on a
compile server. This is done with the command "pts makevers y y"
Where "y y" is like a target in a makefile.
I specify "pts makevers" as the build command, and "y y" as the target, when
I try to build I get this:
Error launching builder (c:/prjtools/107/pt makevers y y )
(Exec error:Launching failed)
Nothing is written in the log.
I'm running on a windows 2000 machine with the latest eclipse and CDT.
-Mads
Re: can't use custom build [message #110858 is a reply to message #110832] Thu, 15 July 2004 13:01 Go to previous messageGo to next message
Mads Andreasen wrote:
> Hi
Did you miss the 's' in pts?
> -Mads
Re: can't use custom build [message #110945 is a reply to message #110858] Fri, 16 July 2004 05:17 Go to previous messageGo to next message
"kesselhaus" <kesselhaus@gmx.net> wrote in message
news:cd6d61$tv4$1@eclipse.org...
> > Hi
Yep!
But alas.. Same result! Still doesn't work.
-Mads
Re: can't use custom build [message #110971 is a reply to message #110945] Fri, 16 July 2004 07:13 Go to previous message
> Hi
>>>Hi
> Yep!
More guessing :)
What happens when using '\' instead of '/'
Previous Topic:Problem with gdb and CDT 2.0 in a cygwin environment
Next Topic:CppUnit 1.1.0
Current Time: Fri Jul 25 00:38:33 EDT 2025
Powered by FUDForum. Page generated in 0.25355 seconds
