The wizard dialog opened by doubled click was unabled responsed to the mouse event , but could respo [message #110803] |
Thu, 08 January 2004 04:06  |
Originally posted by: lizhih.cn.ibm.com
Hi all,
I open a wizard dialog when the user double click a edit part on the
graphical editor , the controls on the wizard dialog such as textbox ,
buttons or combo , could not listen the mouse event , but they could listen
the key press event .
This was happened on the linux redhat 7.3 WSAD IE 5.0 , the mouse event
could be listened on the W2K or windows XP .
Does anyone have met this question before ?
I hope I'm lucky to get a response , thank you in advance.
Re: The wizard dialog opened by doubled click was unabled responsed to the mouse event , but could r [message #110829 is a reply to message #110803] |
Thu, 08 January 2004 11:58   |
I have not seen this problem before. Is it possible that two dialogs are
being opened? One on top of the other? Are you using a MODAL dialog?
If you solve the problem, let us know. IF you don't, try providing code
that will reproduce the example. For example, Take the Logic Example, and
modify one of its editparts to open a dialog similar to the one you are
opening.
"hellen" <lizhih@cn.ibm.com> wrote in message
news:btj6f3$rt1$1@eclipse.org...
> Hi all,
listen
FUDForum. Page generated in 0.06850 seconds
