Home » Newcomers » Newcomers » Cannot see launch shortcuts
Cannot see launch shortcuts [message #110743] Fri, 21 October 2005 15:20
Originally posted by: dtingstrom.atc-nycorp.com
I am trying to add a perspective to my plugin's launch shortcuts. I want
to see the menu item when I right click in a Java Editor window, and go to
the Run As.. menu. I found in the documentation how to do it, but it
doesn't seem to be working. Here is a snippet of code from my plugin.xml
file:
<extension
point="org.eclipse.debug.ui.launchShortcuts">
<shortcut
class=" org.eclipse.jdt.internal.debug.ui.launcher.JavaApplicationLa unchShortcut "
icon="icons/obj16/fuselet_launch.gif"
id="com.atc_nycorp.iFUSE.debug.ui.shortcut6"
label="com.atc_nycorp.iFUSE.debug.ui.shortcut6"
modes="com.atc_nycorp.iFUSE.debug.ui.shortcut6">
<contextualLaunch>
<contextLabel
label="com.atc_nycorp.iFUSE.debug.ui.contextLabel2"
mode="run"/>
</contextualLaunch>
</shortcut>
</extension>
As of now, the class where it points to doesn't really matter. I just want
to see it first in the Run As... menu. All I see now when I right click on
a Java Editor window in the Run As... menu is 2 options: "JUnit Plug-in
Test" and "JUnit Test". I don't even see the old options for "Java Applet"
or the other perspectives anymore. Does anyone have any idea what can
misconfigure this Run As... menu and how?
Thanks.
Previous Topic:Paging in help texts (how to ?)
Next Topic:Eclipse GUI local, running from remote machine
Current Time: Fri Jul 18 10:08:02 EDT 2025
Powered by FUDForum. Page generated in 0.10134 seconds
