Home » Modeling » GMF (Graphical Modeling Framework) » GMF Tutorial - Mindmap Ecore
GMF Tutorial - Mindmap Ecore [message #110738] Sun, 11 March 2007 11:09 Go to next message
Originally posted by: rb_account.yahoo.de
Hello!
I just finished the beginner's tutorial and created the Mindmap Modellin=
g =
Tool.
Everything works fine.
However, I have a question concerning the ecore-Meta-Model =
( http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmf/exa mples/org.e=
clipse.gmf.examples.mindmap/model/mindmap.ecore?root=3DTechn ology_Projec=
t&view=3Dmarkup&content-type=3Dtext%2Fvnd.viewcvs-ma rkup&revision=3DHEAD=
The Meta-Model uses Annotations to extend the MetaData. What purpose do =
these annotations have? Is there any documentation on how to use these =
specific annotations?
Rainer
Example of the annotations used in the Mindmap.ecore
<eClassifiers xsi:type=3D"ecore:EClass" name=3D"Map">
<eAnnotations =
source=3D"http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key=3D"name" value=3D"Map"/>
<details key=3D"kind" value=3D"elementOnly"/>
</eAnnotations>
<eStructuralFeatures xsi:type=3D"ecore:EReference" name=3D"rootTopi=
cs" =
upperBound=3D"-1"
eType=3D"#//Topic" containment=3D"true" resolveProxies=3D"false=
<eAnnotations =
<details key=3D"kind" value=3D"element"/>
<details key=3D"name" value=3D"rootTopics"/>
</eAnnotations>
</eStructuralFeatures>
Re: GMF Tutorial - Mindmap Ecore [message #110762 is a reply to message #110738] Sun, 11 March 2007 14:51 Go to previous message
--------------010406030206020703050000
Rainer,
Have a look at:
XML Schema to Ecore Mapping
< http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf>
These annotations will direct the serialization of the instance to
respect the original schema (or to serialize the way the annotation
specifies since you can add these manually to any model).
Rainer Bernhard wrote:
> Hello!
> Modelling Tool.
> ( http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmf/exa mples/org.eclipse.gmf.examples.mindmap/model/mindmap.ecore?r oot=Technology_Project&view=markup&content-type=text %2Fvnd.viewcvs-markup&revision=HEAD).
> do these annotations have? Is there any documentation on how to use
> these specific annotations?
> Thanks
> Rainer
> <eClassifiers xsi:type="ecore:EClass" name="Map">
> <eAnnotations
> source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
> <details key="name" value="Map"/>
> <details key="kind" value="elementOnly"/>
> </eAnnotations>
> <eStructuralFeatures xsi:type="ecore:EReference" name="rootTopics"
> upperBound="-1"
> eType="#//Topic" containment="true" resolveProxies="false">
> <eAnnotations
> <details key="kind" value="element"/>
> <details key="name" value="rootTopics"/>
> </eAnnotations>
<html>
<head>
http-equiv="Content-Type">
</head>
Rainer,<br>
<br>
Have a look at:<br>
<blockquote><a
href=" http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf">XML
Schema to Ecore Mapping</a><br>
</blockquote>
specifies since you can add these manually to any model).<br>
<br>
<br>
<blockquote cite="midop.to05p8uofmd91d@rabe" type="cite">Hello!
<br>
<br>
Modelling Tool.
<br>
<br>
<br>
(<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmf/exa mples/org.eclipse.gmf.examples.mindmap/model/mindmap.ecore?r oot=Technology_Project&view=markup&content-type=text %2Fvnd.viewcvs-markup&revision=HEAD"> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmf/exa mples/org.eclipse.gmf.examples.mindmap/model/mindmap.ecore?r oot=Technology_Project&amp ;view=markup&amp;content-type=text%2Fvnd.viewcvs-markup& amp;amp;revision=HEAD </a>).
<br>
<br>
<br>
<br>
<br>
<br>
Rainer
<br>
<br>
<br>
<br>
<br>
Previous Topic:Probable BUG during renaming of a node with custom size
Next Topic:Indeterministic error when changing properties
Current Time: Sat Jul 26 09:12:13 EDT 2025
Powered by FUDForum. Page generated in 0.27410 seconds
