Modeling and generating simple interface operation messaging style [message #10079] |
Wed, 28 May 2008 22:49  |
I am trying to figure out the best approach to model the two most common
operation patterns (or MEP);
- one-way (In-only)
- request-response (In-Out)
The following is a simplified representation of these two operations:
One-way: void operation(input1, input2, inputN)
Request-response: void operation(input1, input2, inputN, output1, output2,
outputN)
Return is always void. The parameters can be a sequence of; Inputs, Ouputs
or both at the same time.
In the case of the One-way, a single request message is defined using the
input parameters
In the case of the Request-response, two messages are defined based on
appropriately identified parameters (In, Out, both/InOut).
Based on the Tigerstripe current capabilities I see the following
limitations:
- Editing a method of an interface (Session Facade) is limited; lack of
visibility of the parameters type and name (In, Out, InOut)
- Assigning stereotypes to each individual parameters
- Assigning various exceptions to a request-response operation
Let me know if I am correct in the above evaluation. It seems the best
approach would be to extend Tigerstripe with a special artifact type
(primary operation?), the same way as Query and UpdateProcedure are already
defined.
Jerome
Re: Modeling and generating simple interface operation messaging style [message #10126 is a reply to message #10079] |
Thu, 29 May 2008 05:26  |
Hi Jerome,
not sure I fully understand your assessment of limitations:
> limitations:
lack of visibility of the parameters type and name (In, Out, InOut)
From your next comment, I am assuming that you are adding a Stereotype to
each parameter to identify if it is In, Out, Inout ? If so is the issue
that you cannot see those Stereotypes when looking at the list of
parameters? We may be able to do someting with the display to improve this.
This should be possible - is there something that doesn't work - or is it
just "fiddly"?
Again this should be straightforward You should just need to select
exceptions that exist in your model. Can you expand on the problem?
Richard
Re: Modeling and generating simple interface operation messaging style [message #563289 is a reply to message #10079] |
Hi Jerome,
> limitations:
just "fiddly"?
Richard
FUDForum. Page generated in 0.07219 seconds
