Home » Language IDEs » Java Development Tools (JDT) » "Link with editor" does not work for Hierarchy view
"Link with editor" does not work for Hierarchy view [message #110497] Sat, 25 October 2003 17:52 Go to next message
I am using Eclipse 3.0M4 on windows 2000.
I select the Hierarchy view and then select "link with editor" from the
drop down menu of Hierarchy view (the menu item "link with editor" now
appear with a check mark).
Expected behavior:
When I select a file (.java) from editor window, the hierarchy view
should display that classes hierarchy. When I swith to a different .java
file in the editor, the hierarchy view should show hierarchy for that file.
Behavior seen:
When started, the view show message "To display the type herarchy,
select a type (..), and select the 'Open type hierarchy' menu option. ...."
When a .java file is select from the editor list, it's hierarchy is not
getting displayed. The hierarchy is still the hierarchy of old type
which got shown by selecting "Open type hierarchy" from explorer context
menu.
Looks like the option "Link with editor" is not working for hierarchy view.
I am sure I have seen the same behavior with Eclipse 2.1, latest
release, as well and on every 3.0 milestone build as well.
Am I doing anything worng? Is this a bug?
Prashant Rane
Re: "Link with editor" does not work for Hierarchy view [message #110696 is a reply to message #110497] Mon, 27 October 2003 04:22 Go to previous message
Originally posted by: daniel.megert.gmx.net
Prashant Rane wrote:
> the drop down menu of Hierarchy view (the menu item "link with editor"
> now appear with a check mark).
Check bugzilla for feature/bug reports (including closed ones) related
to this.
Dani
> Expected behavior:
> .java file in the editor, the hierarchy view should show hierarchy for
> that file.
> Behavior seen:
> not getting displayed. The hierarchy is still the hierarchy of old
> type which got shown by selecting "Open type hierarchy" from explorer
> context menu.
> view.
> Prashant Rane
Previous Topic:Programatically create watch expression
Next Topic:Fragments for PDE Junit testing - Classloader problem
Current Time: Tue Jul 22 00:48:56 EDT 2025
Powered by FUDForum. Page generated in 0.71593 seconds
