Home » Language IDEs » Java Development Tools (JDT) » newbie : 30M4 : how to get plugins/org.eclipse.jdt.ui.examples.projects
newbie : 30M4 : how to get plugins/org.eclipse.jdt.ui.examples.projects [message #110470] Sat, 25 October 2003 17:17 Go to next message
Originally posted by: r..lst.bart.nl
Hi all, I am doing my first steps, and I follow the help docs of
30M4. it says "download example code for JUnit here" but
when I follow the link, the zipfile is not there.
I hoped it was maybe included in 30M4 but it is missing from
the plugings directory.The closest match is
plugings/org.eclipse.jdt.ui_3.0.0 but that directory does not contain
anything resembling an example.
Any tips on how I can obtain the missing code ?
TIA,
Ronald van Aalst
Re: newbie : 30M4 : how to get plugins/org.eclipse.jdt.ui.examples.projects [message #110672 is a reply to message #110470] Mon, 27 October 2003 03:01 Go to previous messageGo to next message
Originally posted by: eclipse.tkilla.ch
Go to the eclipse download page, select your favorite build; scroll down
to the examples section and download the "Example plug-ins".
-tom
> TIA,
> Ronald van Aalst
Re: newbie : 30M4 : how to get plugins/org.eclipse.jdt.ui.examples.projects [message #110876 is a reply to message #110470] Mon, 27 October 2003 08:53 Go to previous message
> TIA,
> Ronald van Aalst
Ronald
Did you already download the example zip and unzip it? If so, you might
have done what I did and unzipped it to the eclipse directory itself. If
so, then in your eclipse directory you'll have another eclipse directory
with a plugin folder under it. Move everything frommthat plugin folder
to the plgin folder under the main eclipse directory and then you can
delete the second eclipse directory and everything under it. Did all of
that make sense? If it is just that you can't find the zip file to
download then do what Tom said and go to the download page for your
build and it'll be listed there in the examples section.
Hope that helps
Dave
Previous Topic:How can I include a new Task ?
Next Topic:Java editor signs as error variable declaration of friendly scoped class
Current Time: Tue Jul 29 02:46:59 EDT 2025
Powered by FUDForum. Page generated in 0.05724 seconds
