Home » Archived » BIRT » BIRT Stand alone version 1 example
BIRT Stand alone version 1 example [message #110450] Tue, 17 January 2006 12:34 Go to next message
Originally posted by: m.n.com
Where is there a good example of how to generate a PDF that won't be
saved to the HD in BIRT version 1? I am trying to look at ReportRunner
but I am not sure which one and where.
Re: BIRT Stand alone version 1 example [message #110513 is a reply to message #110450] Tue, 17 January 2006 13:08 Go to previous messageGo to next message
Maybe just a pointer to ReportRunner for BIRT 1?
Re: BIRT Stand alone version 1 example [message #110572 is a reply to message #110513] Tue, 17 January 2006 12:35 Go to previous messageGo to next message
Mark,
For BIRT 1.0 RunReport.java is located on the website
http://www.eclipse.org/birt/index.php?page=deploy/engine.htm l
ReportRunner.java is in the source code under
org.eclipse.birt.report.engine.api, just look for version 1.0.1 in CVS and
check it out.
Jason Weathersby
BIRT PMC
"Mark" <m@n.com> wrote in message news:dqjbqe$tc$1@utils.eclipse.org...
Re: BIRT Stand alone version 1 example [message #110650 is a reply to message #110572] Tue, 17 January 2006 18:59 Go to previous message
Jason,
Thanks. I think I got things finally working. But I am going to
give that class a once over. The one thing that I was missing was that
I actually DID have to point to the [correct] BIRT plugin in addition to
having the classes on the class path. I'll share what I did in case
anyone wants some simple code.
I am using the JPDFViewer, and so far, it looks pretty good.
Mark
Jason Weathersby wrote:
> Mark,
> check it out.
> Jason Weathersby
> BIRT PMC
Previous Topic:Collection as Report Parameter
Next Topic:About URL Redirect
Current Time: Thu Jul 24 01:08:08 EDT 2025
Powered by FUDForum. Page generated in 0.06144 seconds
