Home » Modeling » BPEL Designer » Couldn't resolve WSDL import at location [null].Please check that the resource i
Couldn't resolve WSDL import at location [null].Please check that the resource i [message #10050] Mon, 26 November 2007 11:46 Go to next message
Originally posted by: esk112.hotmail.com
Hello guys/gals
I get this problem when I create a partner link in the designer and then
try to publish my BPEL
resource is accessible.
What is happening here and how should I resolve it?
Re: Couldn't resolve WSDL import at location [null].Please check that the resour [message #10098 is a reply to message #10050] Sat, 01 December 2007 12:40 Go to previous message
Originally posted by: exquisitus.bugmenot.com
I used to have a similar problem when trying to publish my BPEL process,
although the error message I got only said 'NullPointerException'. Anyway,
the problem occured because the WSDL-defintions that I used for my partner
links used the <import>-tag which obviously creats some trouble in the
bpel designer at the moment.
I imported the needed WSDL-definitions into the project and edited out
(deleted) all <import>-tags. After that I had no more problems
publishing...
If that is an option for you, give it a try. It might be due to the same
reason.
~ Eric
Previous Topic:Eclipse Plugin and Oracle Bpel Process Manager
Next Topic:Plugin for Active BPEL Problem??
Current Time: Sat Jul 12 20:14:38 EDT 2025
Powered by FUDForum. Page generated in 0.44239 seconds
