Home » Archived » Test and Performance Tools Platform (TPTP) » Profiling application plug-ins that use Log4j
Profiling application plug-ins that use Log4j [message #110410] Mon, 27 August 2007 13:27 Go to next message
--------------050003010703040401060103
I'm trying to profile an Eclipse command line application plug-in that
uses Log4j for logging. I encountered the following issue first in a
larger application but I narrowed it down to a small plugin (see the
attachment).
The attached plugin does the following:
- extends the org.eclipse.core.runtime.applications extension point and
provides an application implementation
(tptptestplugin.TptpTestApplication class);
- declares a dependency to the org.apache.log4j plugin (the results are
also the same if the log4j JAR is bundled inside the plugin);
- the application implementation instantiates a Log4j logger and tries
to log a message.
The application executes as expected. However, when trying to profile
it, the following stack trace is dumped:
<code>
log4j:ERROR Could not instantiate class
[org.eclipse.hyades.logging.log4j.XmlLayout].
java.lang.ClassNotFoundException: org.eclipse.hyades.logging.log4j.XmlLayout
at java.lang.ClassLoader.findClass(Unknown Source)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:429)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at org.apache.log4j.helpers.Loader.loadClass(Loader.java:178)
org.apache.log4j.helpers.OptionConverter.instantiateByClassN ame(OptionConverter.java:317)
org.apache.log4j.helpers.OptionConverter.instantiateByKey(Op tionConverter.java:120)
org.apache.log4j.PropertyConfigurator.parseAppender(Property Configurator.java:641)
org.apache.log4j.PropertyConfigurator.parseCategory(Property Configurator.java:612)
org.apache.log4j.PropertyConfigurator.configureRootCategory( PropertyConfigurator.java:509)
org.apache.log4j.PropertyConfigurator.doConfigure(PropertyCo nfigurator.java:415)
org.apache.log4j.PropertyConfigurator.doConfigure(PropertyCo nfigurator.java:441)
org.apache.log4j.helpers.OptionConverter.selectAndConfigure( OptionConverter.java:468)
at org.apache.log4j.LogManager.<clinit>(LogManager.java:122)
at org.apache.log4j.Logger.getLogger(Logger.java:117)
at tptptestplugin.TptpTestApplication.<clinit>(TptpTestApplication.java:17)
</code>
Does anyone have an idea about what I am doing wrong? Could this be a
TPTP profiler bug?
Robert
Content-Type: application/x-zip-compressed;
name="TptpTestPlugin.zip"
Content-Disposition: inline;
filename="TptpTestPlugin.zip"
UEsDBBQACAAIAEyiGzcAAAAAAAAAAAAAAAAZAAAAdHB0cHRlc3RwbHVnaW4v LmNsYXNzcGF0
aJ2PPQvCMBRFZwX/Q8huqptDaxGpoEOVUmepyaONxpeYD9F/b1WKLjq4vXs5 nMuL0+tJkQtY
JzUmdMxGlAByLSTWCd2Wi+GEptNBP+aqcs5UvmlD750Avb2Ro0SRUGc5JY/y dUbfSa6xI7Wt
GXAljQN2EJ6pKiBv2nW2KrLdfJ2Xs2WeFX/YjADGtQVm4RykBbFRoZbofql0 8Cb4zraX+ITj
6PP7O1BLBwjVHJzSpQAAADMBAABQSwMEFAAIAAgATKIbNwAAAAAAAAAAAAAA ABcAAAB0cHRw
dGVzdHBsdWdpbi8ucHJvamVjdL2SzW4CIRSF15r4Dmb2QrtzgWNim+7aNLE+ AMJ1xAwXAozp
4xcoo5lMTFwYw+aewz18/LH1r27nZ3BeGVxVr+SlmgMKIxU2q2r387FYVut6 NmXWmROI8A5e
OGVD7I7uhCHXUAcbB/hg265RyGg206wwWgOGmtG+Sm5ZymdBB2rfqVZuLYik inyLUY4yOwVo
XENAtMp6ICcZiDAuFvzMcwDcdQsxwV3TJbYvmg4NRkeUu7hWAvnkqA7x4Jvn YrfiCJo/BFqc
/sojL3QOSve/GOG/8zN/5clEz023AoPnwVGmrxPx8heGn+wPUEsHCI0RUy/p AAAAowIAAFBL
AwQUAAgACABMohs3AAAAAAAAAAAAAAAAHwAAAHRwdHB0ZXN0cGx1Z2luL2J1 aWxkLnByb3Bl
cnRpZXMrzi8tSk7V01OwVSguStbn5covLSkoLQELJGXmAQWApF5mXnJOaUpq MVDQ1zXEUdfT
z01fJ4aXSwEV6GERK8gpTQeaUJGbg0UyJzMJaAMAUEsHCKc51ZBPAAAAhAAA AFBLAwQUAAgA
CABMohs3AAAAAAAAAAAAAAAAGQAAAHRwdHB0ZXN0cGx1Z2luL3BsdWdpbi54 bWxlUDsOwyAM
3Sv1Doi9pJ+lAyTq0hOkB4iIFVkigIBUOX7dkiZUtReen5/9sGzm0bAnhIjO Kn4SR87Aatej
HRR/tPfDlTf1ficb0AZ9hK33Is6Z8mYa0NKLMSZhTmDfDR+YA3vFk6e8eW9Q d4loXvDeoU2K
uzCIZYvQLoAIk004gug2WeT1VyiLcl1MkyQrYA5tuhgXFxBTtixagi3B0tfP qIpmbQurv42y
Wv9LBbpFtR7jBVBLBwgwtvAuswAAAFoBAABQSwMEFAAIAAgATKIbNwAAAAAA AAAAAAAAACMA
AAB0cHRwdGVzdHBsdWdpbi9NRVRBLUlORi9NQU5JRkVTVC5NRl2OQW4CMQxF 9zlFDkCiglgN
6gJQd4BGgNib1AyuMklIHCQ4PYHpUMrKst7z91+CowMmVjuMibyr5FB/iFl2 3xbV8hc+2agn
K2ixktvAgQsPNjfkZF2GItc7m0u795ZM5/I/d5LINRa5hH5yzNjfvLb46zE1 TGdgH99j9L3B
tqz1Y316Yo2nTBFVF1BJHxuNxlJIqI2PqGN2TC0OxANBAHNEbX0z/hFfnacW cL1sGCKXry8V
5xZSqoGPldTiBlBLBwh7+FqIvQAAAD8BAABQSwMEFAAIAAgATKIbNwAAAAAA AAAAAAAAADsA
AAB0cHRwdGVzdHBsdWdpbi9iaW4vdHB0cHRlc3RwbHVnaW4vVHB0cFRlc3RB cHBsaWNhdGlv
bi5jbGFzc5VTa0/UQBQ9AyzdrVVgcXmIjxVRdnlVEZ+LJLjBR9KIkZXvQx3K kNKp7ayBf6WY
IPGDP8AfZbzTXZeHErXNdHpv77n3zLm33398/QZgHksWuhjGdUy3SHUcNgMZ uQ0yG2Qux3Eo
fa6liiz0MPRv8w/cDXkUuKsb28LXFnoZJlQSuMIPZZwKV7xvykjtujyO3ZfH 8Azd3upzhlHP
RPOY+1vCDVWwsO16KghEUmPIL1KSSOolCq5U1xl66uqdsHEefRYuMAyfAXXQ jwGGQiB0y8Ew
U/GOuNZDnqa16pmVC2AYdGAhz9DnyUi8au5siKTBN0LBUPSUz8N1nkhjt529 ixlRG90YcTAE
m8jqLZmSGt7fxaSz5lLNE82wXPH+Rb66irTY1XSI0y2gXPbKri9iE5ZauEZn OYrpfCngOm5Y
GD/RxLW9VIsdBxO4SZKrJvEptQpI5b5OZKTXdCL4Ti2PSWpdI9mTUVDWquyr aFMGzUSUPSOk
jSqmLUz9Kn0S7WAGswxWbFwhTULpeHMohpLWqus2XNyxcJvG8bdGPeWp9Ovt olwravm80bzQ
IZLHArXgxcqbFTMv9x08wENyyGhTnSrYls3Ml+W3ZGWY/a8uUOJUq5iUX1PN xBfPpJmJkT90
es7UJelJXlo5WpfNnNG/10PPAmzynCNrlnZzFYrsEM5nFD+R0YWL9LRpBwYo vA+lzAsKHupA
XdoNODf1BcNHsN7M2YI4rQCM4lIGHiMWXbiSsWC4mqV5Sx6TurSPcvHWASqH mNtHsXj3APfY
x07aIkGAEWIzSrAxDFIaU2KoBW6XMG+P8DhjVuswnc6K0zrNcvIYS9ZhuZhF PfkJUEsHCDH8
UHx7AgAArAQAAFBLAwQUAAgACABMohs3AAAAAAAAAAAAAAAAPwAAAHRwdHB0 ZXN0cGx1Z2lu
L2Jpbi90cHRwdGVzdHBsdWdpbi9UcHRwVGVzdFBsdWdpbkFjdGl2YXRvci5j bGFzc42Sb0/T
UBTGn7t1K61lKDgUGU6QzTETm+hLjImCGJKFkDD21lzKpV7t2ub2FvlY/nlB 4gs/gB/KeO7d
hGgikib3nnN6+jvPc9IfP799B/AUXRcVhq7O6RGFzpMylmk4pHRI6b5NX0Za nnKdKRcOQztT
cSiiROaFCKNMiVCVqZZjEU66Gbz9weGb3b23u9sM84P3/JSHCU/j8EArmcab DLNbWVponuoR
T0oxA4+h8acChvrvoDe4njji1p/LVOoXDNXexojB2cqOhY8qbgYIMMswN5Cp 2CvHR0IN+VEi
jLws4smIK2nyadHR72TBUCOJSjN0egNjOStiGZ4oPhYfM/UhfFWmx4kgI1qc 6U0zzn99Folc
S/Lm4i7DwqXzizdGzb0At9H0wNAK4OMGgxtNMAxr/x9F+gqd5Ya0GqCNJk2O hd4WJ7xMCNHv
bVx/Y/5BVqpI7Ejju/WPvifGCFZJcJX+mQqWUEOdMtdmM+SBXFDsUI32TGeD smd0M7pr/XPM
fbatt+j06QYtwEET8xQFkyYsWAQzq6GOxSnujkXtUMV85fcfn2Op/xXLl7yG FdUiwgo83LfM
xUn3lGmiFXpj5LSvojMCmwkP/qZ3qLtL9EdX0j2s4eHU/Lp1RVO+YPnTBa1u q6GlVKzbdRt1
fgFQSwcI1kHp9+0BAACPAwAAUEsDBBQACAAIAEyiGzcAAAAAAAAAAAAAAAA6 AAAAdHB0cHRl
c3RwbHVnaW4vc3JjL3RwdHB0ZXN0cGx1Z2luL1RwdHBUZXN0QXBwbGljYXRp b24uamF2Ya2S
3WobMRCFr9fgdxjcm40h2pvchULS1vSHwELrF5DlsSxX1qjSyHUoffeOdp1i mqQ0UJZdtOLM
zPkO083n0wkMbzedRG2+aovAUR7MHH2xLlxPJ9OJ20dKDJSs0iLbovJkr3bq jc7OvKWwcbYk
zZSun9fekbX4hwCNdzGjwm/FBTpKQVQfb2P0zmh2FF6mFiOMRx4cdyMa3OjC W0qQaIWJz2nL
SurAeJ0zLAV5KchnzUAGe9xj4AznQ+BHbd/ERIyGcQ2Z5d7AxgXtYYSEu/49 vD79KIs8nton
xqjBwMXguenm0AYKl5/0Qa/JXMhVRciI/8T/Sqwkbl8Q1ThB0mhu+gOm5NZY 2cZo+tVOCGFs
+kQxmFMT4G2i7xkWR4PxIaOm+XKfGfeKCquYXGAf2tky3btggakWD1uDNaar 3axG0DSPFkr9
1rWnkBoJV7mwoXb2YfF5MXu4TsglBQjF+9rq539KlGL715QO5OoOVNmI3XWw 7N/1cFuYLi0G
FA5Zkz3KHlZlWQ3OBn/y+QVQSwcIkH5pdo0BAACEAwAAUEsDBBQACAAIAEyi GzcAAAAAAAAA
AAAAAAA+AAAAdHB0cHRlc3RwbHVnaW4vc3JjL3RwdHB0ZXN0cGx1Z2luL1Rw dHBUZXN0UGx1
Z2luQWN0aXZhdG9yLmphdmGtU11rGzEQfD6D/8OSvtiG3P0AE0hTl+BQSmic 56Do1mcRWRKr
lZNS+t+7ug/HaTAhIRzcwWp2NDO7F5R+UA0CB3kwcrCpMW4+Ho1HZhs8MXhq StTWhIil9oQl
Jcdmi+X1AD0A+tiYck1qi4+eHsqL5GqL37xjfOKWtJrNxiOYwWqDoDSbnWJP oK2KEbTgyNsI
LIdZyKlxYM0aQf/WFnNfNR6FdG+N7ltWInslsjstX/eEch26OkJXhz/56qKq 2msH5uVCaj1b
ZMXyWRunLNwwGdfA9Y/by+XPu+UCzuDkZT4n80PCuFGENRgnLE5jZqWsAwfa Yyr3YReZLCdT
9NFIFJEpaUG1xepZ6hGyyTS7LP52wnqqifPu9ErtVO31tCudR8S3Zhq/iHDi yVsTnf6vbedN
DV3vC2A72twgoyX/GOH7k8bAxrejKYqYAlLZNQ7QHEvRJSQD4I2J88/yJ/Z8 +LA7aX2Xub0H
l6ydH9oVpkO3g7fe3C/kRK77G16vGPSoc2phR1HVqyU/to0N8gLXKlnud6no qZ/XtFUor39Q
SwcIrT+Iu54BAAA2BAAAUEsBAhQAFAAIAAgATKIbN9UcnNKlAAAAMwEAABkA AAAAAAAAAAAA
AAAAAAAAAHRwdHB0ZXN0cGx1Z2luLy5jbGFzc3BhdGhQSwECFAAUAAgACABM ohs3jRFTL+kA
AACjAgAAFwAAAAAAAAAAAAAAAADsAAAAdHB0cHRlc3RwbHVnaW4vLnByb2pl Y3RQSwECFAAU
AAgACABMohs3pznVkE8AAACEAAAAHwAAAAAAAAAAAAAAAAAaAgAAdHB0cHRl c3RwbHVnaW4v
YnVpbGQucHJvcGVydGllc1BLAQIUABQACAAIAEyiGzcwtvAuswAAAFoBAAAZ AAAAAAAAAAAA
AAAAALYCAAB0cHRwdGVzdHBsdWdpbi9wbHVnaW4ueG1sUEsBAhQAFAAIAAgA TKIbN3v4Woi9
AAAAPwEAACMAAAAAAAAAAAAAAAAAsAMAAHRwdHB0ZXN0cGx1Z2luL01FVEEt SU5GL01BTklG
RVNULk1GUEsBAhQAFAAIAAgATKIbNzH8UHx7AgAArAQAADsAAAAAAAAAAAAA AAAAvgQAAHRw
dHB0ZXN0cGx1Z2luL2Jpbi90cHRwdGVzdHBsdWdpbi9UcHRwVGVzdEFwcGxp Y2F0aW9uLmNs
YXNzUEsBAhQAFAAIAAgATKIbN9ZB6fftAQAAjwMAAD8AAAAAAAAAAAAAAAAA ogcAAHRwdHB0
ZXN0cGx1Z2luL2Jpbi90cHRwdGVzdHBsdWdpbi9UcHRwVGVzdFBsdWdpbkFj dGl2YXRvci5j
bGFzc1BLAQIUABQACAAIAEyiGzeQfml2jQEAAIQDAAA6AAAAAAAAAAAAAAAA APwJAAB0cHRw
dGVzdHBsdWdpbi9zcmMvdHB0cHRlc3RwbHVnaW4vVHB0cFRlc3RBcHBsaWNh dGlvbi5qYXZh
UEsBAhQAFAAIAAgATKIbN60/iLueAQAANgQAAD4AAAAAAAAAAAAAAAAA8QsA AHRwdHB0ZXN0
cGx1Z2luL3NyYy90cHRwdGVzdHBsdWdpbi9UcHRwVGVzdFBsdWdpbkFjdGl2 YXRvci5qYXZh
UEsFBgAAAAAJAAkAGwMAAPsNAAAAAA==
--------------050003010703040401060103--
Re: Profiling application plug-ins that use Log4j [message #110447 is a reply to message #110410] Tue, 28 August 2007 01:57 Go to previous messageGo to next message
Sorry, I forgot to specify my system setup:
- Eclipse 3.3
- TPTP 4.4 (latest from the Europa discovery site)
- both JDK 1.6.0_02 and JDK 1.5.0_12
Robert
Robert Enyedi wrote:
> attachment).
> to log a message.
> <code>
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> </code>
> TPTP profiler bug?
> Robert
Re: Profiling application plug-ins that use Log4j [message #112266 is a reply to message #110447] Wed, 12 September 2007 12:15 Go to previous message
Just for the record, I reported the bug and it does not show up in the
latest TPTP 4.4.1 development builds. See this bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=201406
> - Eclipse 3.3
> Robert
>> attachment).
>> and provides an application implementation
>> are also the same if the log4j JAR is bundled inside the plugin);
>> to log a message.
>> <code>
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> </code>
>> TPTP profiler bug?
>> Thanks,
>> Robert
Previous Topic:[Linux] Several issues...
Next Topic:"TPTP Automated GUI Test" test suite missed !
Current Time: Sun Jul 27 06:28:42 EDT 2025
Powered by FUDForum. Page generated in 0.03960 seconds
