Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP X File
TPTP X File [message #110397] Mon, 27 August 2007 13:00 Go to next message
Hi all,
from eclipse using TPTP with IAC I'm experiencing the following X file:
1. I select Project , Profile As > Java application > JAva Profiling 1.5
> OK button --> IT fails because it cannot connect to 10006 port
2. Without closing the window, i seslect JAva PRofiling 1.5 and press
"Test Availability" button and I get a sucessful message
3. I repeat point 1 exactly as before and now it works perfectly !!
Some screenshots at:
http://tlloreti.googlepages.com/TPTP_XFile.doc
Can someone explain me what "Test Availability" button does to make it work?
Thanks!
T
Re: TPTP X File [message #110592 is a reply to message #110397] Wed, 29 August 2007 02:00 Go to previous messageGo to next message
Hi Tatiana
What TPTP build are you using?
"Test availability" button launches profiling of sample application.
Igor
Re: TPTP X File [message #110603 is a reply to message #110592] Wed, 29 August 2007 02:40 Go to previous message
Hi Igor, I'm using tptp 4.4.0.2
Yes, i imagined that, that's why i find that it is very strange that i
only can profile my application if I press this button first
Thanks!
T
Igor Alelekov escribió:
> Hi Tatiana
> Igor
Previous Topic:Problem with IAC
Next Topic:Debug trough Hibernate w/ TPTP?
Current Time: Fri Jul 25 14:03:40 EDT 2025
Powered by FUDForum. Page generated in 0.03915 seconds
