Home » Archived » Tigerstripe » Several questions as starting to use Tigerstripe
Several questions as starting to use Tigerstripe [message #10033] Tue, 27 May 2008 22:18 Go to next message
Hi All,
I started using the latest Tigerstripe workbench as part of the TMF
Interface
Program(org.eclipse.tigerstripe.workbench.base_0.3.0.M200805 061422_incubation)
I have the following questions :
- Is the Eclipse Tigerstripe Help aligned with the latest version
(Tigerstripe Workbench 2.x)?
For example, it says TS comes with three default basic plug-ins. It was true
before but I don't see that now.
It seems that it does not reflect the latest TS architecture changes? I also
still see many references to OSS/J. I thought they had been removed to make
TS generic?
- Failing to access plugin project global properties from a template in a
test model project using $pluginRef.Properties.getProperty.
Template is in Refer to plug-in and test model project in TMF GForge TIP SVN
repository at respectively : Teams\Framework\TIDE\xml_plugin and
Teams\Framework\TIDE\xml_plugin\templates\wsdl\wsdl.vm.
- Failing to define stereotypes to artifact, methods, parameters. The
stereotype selection is empty. I can't find in the help pages where, how to
create stereotypes?
Jerome
Re: Several questions as starting to use Tigerstripe [message #10056 is a reply to message #10033] Wed, 28 May 2008 12:25 Go to previous messageGo to next message
Hi Jerome,
See my comments inline.
Eric
On 5/27/08 7:18 PM, in article g1ifds$5vf$1@build.eclipse.org, "Jerome
Magnet" <jeromem@nortel.com> wrote:
> Hi All,
> Interface
> TS generic?
There has been few posts already in this group about this. No, the Doc is
still aligned with the old commercial version. We are working on the changes
but they won't be in place until mid-june.
I particular, the basic plugins are gone. They were VERY OLD non-compliant
OSSJ plugins.
The TS changes to remove OSSJ stuff are being done as we speak too. We are
working on the 0.3 release stream (check out the dates/details at
http://wiki.eclipse.org/Tigerstripe_0.3_stream ). Most of these changes we
implemented in the 0.3M2 drop as of yesterday. (looks like you're still on
the 0.3M1).
The goal is indeed to make TS generic.
I'll differ this to Richard who is the plugin guru :-).
> create stereotypes?
When definining stereotypes you need to assign a scope of applicability to
them. By default (probably needs to be the other way around) stereotypes are
not in scope for anything, you need to explicitly select what they will be
applicable to.
When defining a stereotype, look at the details, scroll down a little and
you'll see a lot of checkboxes to define where they should be applicable.
Once you've updated this, save your profile and "activated it again" to
apply the changes, the stererotypes should be offered then.
> Jerome
Re: Several questions as starting to use Tigerstripe [message #10103 is a reply to message #10056] Thu, 29 May 2008 05:16 Go to previous message
Hi Jerome.
>> repository at respectively : TeamsFrameworkTIDExml_plugin and
>> TeamsFrameworkTIDExml_plugintemplateswsdlwsdl.vm.
The $pluginref object in the context has been renamed to be $pluginConfig
- that should enable you to get these properties.
>> create stereotypes?
Before you get to Eric's point below, you need to define the stereotypes
in a Workbench Profile, and then apply that to your session.
http://wiki.eclipse.org/Tigerstripe_Profile_Tutorial - iss out of date
:-(, but gives the concepts. In the tutorial, the Steroetypes are called
annotations. (We have put in place a true "annotation" mechanism, so have
given the stereotypes a more meaningful name.)
> When defining stereotypes you need to assign a scope of applicability to
> applicable to.
Richard
Re: Several questions as starting to use Tigerstripe [message #563216 is a reply to message #10033] Wed, 28 May 2008 12:25 Go to previous message
Hi Jerome,
Eric
> Hi All,
> Interface
> TS generic?
OSSJ plugins.
the 0.3M1).
> create stereotypes?
applicable to.
> Jerome
Re: Several questions as starting to use Tigerstripe [message #563266 is a reply to message #10056] Thu, 29 May 2008 05:16 Go to previous message
Hi Jerome.
>> create stereotypes?
> applicable to.
Richard
Previous Topic:Modeling and generating simple interface operation messaging style
Next Topic:Modeling and generating simple interface operation messaging style
Current Time: Sat Jul 26 03:45:46 EDT 2025
Powered by FUDForum. Page generated in 0.05968 seconds
