Home » Modeling » TMF (Xtext) » [TCS] PropertyVal
[TCS] PropertyVal [message #10029] Fri, 11 April 2008 09:43 Go to next message
I see that there is a subtype of Value in the TCS.mk3 called PropertyVal.
However, the TCS Syntax does not define a Template for that? What is this
Value, and why isn't there any syntax for it?
Re: [TCS] PropertyVal [message #10053 is a reply to message #10029] Mon, 14 April 2008 02:22 Go to previous messageGo to next message
> PropertyVal. However, the TCS Syntax does not define a Template for
> that? What is this Value, and why isn't there any syntax for it?
The PropertyVal class was added to do some experimentations. We did not
find any case where it was necessary/relevant. It should probably be
removed, unless we find it some usefulness.
Is there something you want to do for which PropertyVal might be necessary?
Frédéric Jouault
Re: [TCS] PropertyVal [message #10076 is a reply to message #10053] Mon, 14 April 2008 03:42 Go to previous message
No, right now I am mostly trying to find out what is possible, before I
decide what I need.
Previous Topic:[TCS] EnumerationTemplate automatic
Next Topic:[TCS] isDefined vs. Alternative
Current Time: Fri Jul 18 00:17:04 EDT 2025
Powered by FUDForum. Page generated in 0.27030 seconds
