Home » Modeling » BPEL Designer » Generating BPEL programmatically using bpel.model
Generating BPEL programmatically using bpel.model [message #10026] Mon, 05 November 2007 21:59
I would like to use the org.eclipse.bpel.model package to generate BPEL
programmatically. I know that I can create and populate a Process object
using the BPELFactory. Now I want to serialize it to XML. I'd thought I
might be able to use the BPELWriter class, but its write method expects a
BPELResource.
How would I create a new BPELResource and link that to my Process object?
In the BPELResource class, I can only see a getProcess method. Also, I'm
not quite sure which factory to use for the creation of the BPELResource.
I'd be glad if someone could shed some light on this.
Thanks in advance
Leif Singer
Previous Topic:can i read an XML file with the oaw XMIReader class
Next Topic:Eclipse Plugin and Oracle Bpel Process Manager
Current Time: Sun Jul 13 05:17:48 EDT 2025
Powered by FUDForum. Page generated in 0.03343 seconds
